Pioneer vsx-1023 bluetooth / wireless speakers (1 Viewer)
dixondadof3
Anderson, SC
Tom Dixon
Hey gang,
I have a Pioneer VSX-1023. If I purchase the Bluetooth adapter - will I be able to play thru my wired and wireless speakers? I just purchased a Samsung M7 and I need to know if I purchase the Bluetooth adapter, will it play thru the M7? If not, I need to take the speaker back.
Appreciate the help / advice!
Td
dixondadof3
Anderson, SC
Tom Dixon
Well, I did. :) I just wanted to confirm with those with more experience. The words started to run together.
Side note - I am originally from Marion, IN.
Thanks!
schan1269
HTF Expert
Chicago-ish/NW Indiana
Sam
dixondadof3 said:
I was looking for an alternatative to running wires / hiding wires for rear speakers and for my dining room.
You have zero options with the 1023. The 1123, you would have had hundreds of options.
SaladinNagasawa
