Hey Everyone. I recently bought a house that has two in ceiling speakers in the living room (they are in the back of the room, so would be the two rear speakers in a 5.1 system), 1 speaker in the kitchen, and 2 outdoor speakers. I am coming from a small apartment where I made do with what I had and was using a powered soundbar with wireless sub. I have read a lot on here about the drawbacks of using a sound bar, especially for someone trying to get surround sound quality. My issue is I'm currently a little restricted by budget (new house and all), so buying some new speakers and a sub is a little ways off. I do, however, want to find a way to integrate the other speakers already installed in the house if I can.
My thought is to purchase an amp to run all of my inputs through, hook up the bar's Audio IN (probably using HDMI or Fiber Optic) to the Amp (essentially running it as a Center and Front L/Front R) which would activate the sub whenever it is turned on, then hook up the two rear in the living room as Rear speakers. I'll hook up the kitchen & outdoor as channel B so that they can be operated separately.
My question is - has anyone attempted to do this? Will a self-powered sound bar even operate as I am trying to? To me it is the same as plugging just a TV into it, or using an A/V Switch to manually change which input i am using. While i realize I am not going to get the quality a typical 5.1 system with better speakers may provide, I am just looking for a temproary fix until I can scratch some more funds together.
Thanks for any advice or input!
EDIT: I re-read my post and wanted to clarify one thing: Where I said my plan is to use the Audio In on the sound bar, I should have mentioned i'll probably just buy an RCA Audio cable with plugs on one end (for the bar) and wire at the other to hook up into the Center speaker hook up on the amp. If I'm missing something that is going to cause that to not work, please let me know -- I'm a bit of a novice but know just enough to get myself in trouble trying to do this.
