Denon E400 And Samsung F8500 ARC problem (1 Viewer)
mccambley
Casey
Denon E400 And Samsung F8500 ARC problem with no sound from Netflix using smart TV. Anybody know the settings and do I have to use HDMI with Ethernet. Sami HDMI port 3 to Denon HDMI out. select TV sound on Denon and nothing.Tried turning on CEC and nothing.
schan1269
HTF Expert
Chicago-ish/NW Indiana
Sam
After Googling this issue(you can find and read yourself, if you care)...Run a Toslink. Problem solved (like it is every singe time "help ARC doesn't work" is brought up).
mccambley
Casey
schan1269 thanks for the effort. I was afraid that the answer was run an optical, just wanted the ARC to work and I wonder why it does'nt.
schan1269
HTF Expert
Sam
Cause it and CEC(which has to work for ARC to work) is a flawed premise.
Just another answer to questions nobody asked.
Supposedly...CEC/ARC become become "standards" on HDMI 2.0(they are not a "standard" on 1.3/1.4). Not holding my breath.
Hopefully with several AVR manufacturers including AptX(part of BlueTooth) and TV manufacturers adopting it...we can forget ARC ever existed.
schan1269
HTF Expert
Sam
By the way....if the E400 has Bluetooth...
There are Chinese made Toslink to BlueTooth adapters(and they are meant for TV use) for roughly $30.
Not seen any that support more than 2.1 though(as you need AptX to get to 5.1).
acinstallation154
