Jump to content
Help building a home theatre setup
  • Please log in to reply
4 replies to this topic
#1 of 5 OFFLINE   Nikki Erwin
Nikki Erwin
  • 2 posts
Posted July 05 2014 - 01:20 PM
[color=rgb(0,0,0);font-family:verdana, arial, helvetica, sans-serif;font-size:small;background-color:rgb(250,250,250);]So i found a brand new Infinity TSS-3IN1 speaker in my garage the other day and I want to build a system as cheap as possible around it. I have an Xbox One with an optical audio out and would preferably not have to buy any more speakers. Is this possible? What do you recommend?[/color]
#2 of 5 OFFLINE   schan1269
schan1269
    HTF Expert
  • 16,120 posts
  • Real Name:Sam
Posted July 05 2014 - 01:24 PM
Any AVR with an optical and DD.You have every AVR made since 1994 to choose from.
#3 of 5 OFFLINE   Nikki Erwin
Nikki Erwin
  • 2 posts
Posted July 05 2014 - 01:27 PM
Will the setup sound ok with just the 3 speakers or should I invest in a sub and some rear speakers? Also, I have no idea where to go in order to buy just the two rear speakers.
#4 of 5 OFFLINE   schan1269
schan1269
    HTF Expert
  • 16,120 posts
  • Real Name:Sam
Posted July 05 2014 - 01:30 PM
Will the setup sound ok with just the 3 speakers or should I invest in a sub and some rear speakers? Sub, yes.Surround. Your choice. Also, I have no idea where to go in order to buy just the two rear speakers.The TSS line sells well, used are available...and Amazon and other online sites have them new.
#5 of 5 OFFLINE   vidiot33
vidiot33
  • 157 posts
  • Real Name:Mark
Posted July 06 2014 - 06:48 AM
You could see what Infinity offers for rear speakers, to keep the soundstage more seamless
