Hi I am just about to purchase a few components from Sonos but I just need to figure out if everything will work correctly.
My system
- Samsung 55" tv 2012 model
- Marantz receiver NR1604
- intel NUC HTPC (Home Theatre PC)
- some cheap wired front speakers
What I would like to buy:
- Sonos connect
- Sonos rear speakers for a 5.1 set-up
- Sonos sub / playbar
Currently:
- HTPC connected to my receiver via mini display port to hdmi.
- Output from my Marantz receiver going via hdmi to my tv.
- Optical connected from my tv going into my receiver.
- Receiver connected to my temporary font speakers (which I am happy to replace).
How would I add Sonos into this situation...
- Do connect a Sonos connect to my receiver via coaxial?
- Can I then add some rear Sonos Play:5's and it will understand that the wired front are connected but to use the Play:5's as the rear sound?
- When I play movies from my HTPC will the sound come out of the Sonos Play:5's for the rear 5:1? will it understand that the Sonos speakers are there? as there will be no output from the Marantz receiver to the Sonos just an input from the Sonos to the Marantz receiver.
Overall I'm asking if my external sources (HTPC etc) that are connected to my Marantz receiver be able to utilise Sonos speakers to play movie sound using 5.1?
I am happy to lose the front speakers and replace with Sonos speakers but I am worried it won't work and the content I play via my HTPC won't come out of the Sonos speakers?
Sorry I hope I haven't massively over complicated this for myself and thank you for any guidance you can give me.
My system
- Sonos connect
Currently:
