First time projector purchase, going crazy here! Need some advice. (1 Viewer)
Boochy33
Grip
Michael
Alright guys, I'm looking at replacing my TV in my living room with a new projector. Current room setup - http://imgur.com/Y7j8M0gThe plan is to have the projector on the opposite wall of the screen(where the tv currently is), but that's a throw distance of 18 feet(14 feet viewing distance). I'm wanting to purchase a BenQ 1070 or 1080ST, but I'm afraid I'll have to use a ceiling mount(which I'm not comfortable doing). I've also read that at that distance, I'd have to use a larger screen, around 180", and that is way too big.I dont' want to go any bigger than a 120" diagonal screen, so I don't think the 1070 would work that great from 18 feet away.My other projector option is the Epson 8350 since I've read it has a higher zoom and can support an 18 foot throw at 120" and still look great, but I'd rather stay with DLP over the 8350 LCD. At that throw distance, are the BenQ's out of the question unless I use a ceiling mount? If that's my last resort, it would be mounted beside the ceiling fan.
schan1269
HTF Expert
Chicago-ish/NW Indiana
Sam
You realise ST stands for Short Throw, to begin with.If I recall...the last person with a ridiculously long throw went with a Mitsubishi.
Boochy33
Grip
Michael
Right, which is why the 1080ST is probably out of the question(unless I ceiling mount). I guess my main question is, can the 1070 be used at a throw of 18ft with less than a 120' screen, or will I have to use the Epson? Not really looking forward to mounting on the ceiling and running wiring through the attic and down the wall. If I did, the 1080st is the winner.
schan1269
HTF Expert
Sam
ViewSonic Pro8200
InFocus 8606
BenQ W7000/7500
Vivitek 5080
Those are your choices...leaving out the Vivitek 1080(3x color wheel...and the least featured) and everything approaching $5000.
Type A
Aurora Oregon
Ty
Thats not your only option. Paintable, easy to install and very professional looking Ive been very pleased with this stuff...http://www.homedepot.com/p/Legrand-Wiremold-Cordmate-II-Kit-C210/100657473?AID=11210757&PID=6150045&SID=yavi0epkmlo8&cm_mmc=CJ-_-6150045-_-11210757&cj=truePics in my photo gallery, bottom link in my signature.
Boochy33
Grip
Michael
Not bad at all... So I could ceiling mount a 1080ST about 7/8 feet away, grab a 120 inch screen, and cover the wires with those. I can live with that...
Type A
Aurora Oregon
Ty
Just a heads-up from my experience using the stuff...They have a self adhesive backing but it doesnt last in ceiling applications. Use some hot glue, in addition to the self adhesive, for any cable channels mounted on the ceiling. That will ensure a lasting bond ;)
Boochy33
Grip
Michael
Thanks for the help. :) Thanks as well Schan.
schan1269
HTF Expert
Sam
Screws don't cause damage?
It depends if you can mount to the ceiling...or need a pole. I've never checked the 1080ST for lens shift.
Edit:
Just checked...the 1080ST has no lens shift. The projector has to be mounted where it is, essentially, at the same height as the top of the image. So, if your ceiling is 8ft...
The 1080ST has to be mounted 15-18 inches off the ceiling.
Boochy33
Grip
Michael
schan1269 said:
Screws don't cause damage? It depends if you can mount to the ceiling...or need a pole. I've never checked the 1080ST for lens shift. Edit:Just checked...the 1080ST has no lens shift. The projector has to be mounted where it is, essentially, at the same height as the top of the image. So, if your ceiling is 8ft... The 1080ST has to be mounted 15-18 inches off the ceiling.
Thanks, I have a 10ft ceiling.
Another dumb question, when the BenQ Calculator tells me "Projector Distance from the Ceiling - 0'11", is that where the center of the lens needs to be?
Gregg Loewen
Founder, Professional Video Alliance
Insider
New England
Gregg Loewen
the closer the PJ is to the screen (meaning the shorter the throw), the bigger the image is when going through the lense. This means the more distortion you will have (edges fuzzy, chromatic aberrations, etc).
FoxyMulder
映画ファン
Scotland
Malcolm
Boochy33
Grip
Michael
Well, bought the W1070 along with a ceiling mount. I hooked up the projector last night and used it on my light green wall to test, and I was extremely happy with it. This will work fine till my screen comes in next week.Now if I can just find some good calibration settings to use on it.
Jim517
Summit, Wisconsin
Jim
Good choice. You need to calibrate the projector, for your room. Using someone else's settings is virtually worthless. The Disney WOW disc is a very popular, easy to use disc. It allows you to calibrate your audio also.
Boochy33
Grip
Michael
I actually ordered that from Amazon about an hour ago, thanks for the tip. :)After fighting for 3 hours, I finally got it ceiling mounted and up and running. Tomorrow is going to be dedicated to hiding cables. :)
blitz
