Jump to content
Home Theatre System Karaoke Machine
Best Answer Jason Charlton, June 14 2014 - 07:40 AM
Sam is correct. The color of the connectors makes no difference - the colors are there to help you make sure both ends of the same physical wire are connected correctly.
1) For "regular" karaoke, as Sam suggested, use either the coaxial or optical output on the karaoke machine to the corresponding digital input on the AVR (the receiver). Since you have lots of coaxial cables, it probably makes sense to just use one of those for that connection. That's all you need for "regular" karaoke.
2) For "pc karaoke", the only audio FROM the karaoke machine that you want is the microphone audio. HOPEFULLY, that is available via the center channel output on the karaoke machine - again, we don't know for certain. Pick an RCA cable and connect one end to the "center" output on the karaoke machine (like you have done) and the other end to the "center" input on the back of the receiver.
3) For the music part of "pc karaoke", it sounds like you have that set up correctly - using the headphone output from your PC to the Left/Right multichannel inputs. What this means is that when you select the multichannel audio input on the AVR, you will get Left/Right from your PC and center channel from the karaoke machine.
4) We also forgot about the video signal from the karaoke machine. Pick another RCA cable and connect it from the yellow "monitor out" on the karaoke machine to the yellow "in" on the AVRs DVD input. This will work for both forms of karaoke - any time you switch to the DVD input on the AVR, it will show the video from the karaoke machine.
With both devices turned on, select the DVD input on the AVR. If the DVD input is already assigned to the digital coaxial input we used in step 1, regular karaoke should work. If not, you may need to go to the input assignment setup menu on the AVR to make sure that when you switch to DVD, the coaxial digital audio input is used.
For pc karaoke, you will once again select the DVD input (with both devices turned on), but this time, you want to use the multichannel input (instead of the digital coaxial). According to Sam, that should mean pressing the "Multi-Ch" or some such button on the remote control. Consult your manual if you're not sure.
Here's a slightly edited version of your picture, with some connection guidelines.
[attachment=11098:Connections_2.jpg]
Go to the full post
  • Please log in to reply
43 replies to this topic
#41 of 44 OFFLINE   Jason Charlton
Jason Charlton
    Producer
  • 3,168 posts
  • Real Name:Jason Charlton
  • LocationBaltimore, MD
Posted June 29 2014 - 06:25 PM
What happens when you dial the microphone volume dials to max and the music down to zero? What about unplugging one mic if you're only using one? There are a lot of possible combinations and you're the only one with the manual for the mixer.Does the manual offer any suggestions?
Are you new to the Home Theater Forum? Stop by the New Member Introductions area and introduce yourself! See you there!
#42 of 44 OFFLINE   Louis Ahn
Louis Ahn
  • 30 posts
Posted July 02 2014 - 10:07 AM
Right, I've tried using only one mic while the music was turned off but the sound is def a lot less sensitive than the previous set up I had when the mic plugged into the karaoke machine while the video and lyrics played through a tv monitor. One review on amazon said the same thing about maxing out volume but still getting a faint sound. Im thinking maybe it's a cheap mixer thats causing this low sound. I'll have to check the manual though
#43 of 44 OFFLINE   Louis Ahn
Louis Ahn
  • 30 posts
Posted July 12 2014 - 07:32 PM
i figured it out damn. i just had to raise the volume of the surround sound receiver. Once I did that, my mic volume boosted up like crazy, thanks guys. Time for some karaoke time!
#44 of 44 OFFLINE   Sam Posten
Sam Posten
  • 18,542 posts
  • Real Name:Sam Posten
  • LocationAberdeen, MD & Navesink, NJ
Posted July 21 2014 - 05:51 AM
Congrats on getting it fixed.
I lost my signature and all I got was this Nutter t-shirt
HTF Rules
Classified Sales Rules
UV Sales New Clarifications
