Jump to content
Sign up for a free account!
Signing up for an account is fast and free. As a member you can join in the conversation, enter contests and you won't get the popup ads that guests get. Click here to create your free account.
Bose Acoustimass 10 Series IV - no surround sound
  • Please log in to reply
7 replies to this topic
#1 of 8 pmantey
pmantey
  • 2 posts
  • Real Name:Paul Mantey
Posted May 01 2014 - 01:09 PM
So my parents move into a new house and purchase components for their home theater system and ask me to install everything. No big deal, right? Except they selected a finicky Bose surround system. Here's the equipment being used, all of which is new:
- Denon AVR-E400 receiver
- Bose Acoustimass 10 Series IV speakers
- DirecTv Genie
- Samsung 60" 3D LCD
- Sony BluRay player (actually, this is not new, but works fine)
All of the other components work. Picture looks great, DirecTV works, BluRay works. I even have good audio on the TV if I switch the Denon's output to TV instead of AVR.
But the Bose speakers are not cooperating. I can actually get good bass out of the module, but nothing from the center channel, front, or surround speakers. Here are the things I've tried:
- verified that the Acoutimass bass module has AC power.
- checked/double-checked the wiring connections from the receiver to the bass module.
- checked/double-checked the wiring connections from the bass module to the other speakers.
- verified that the Denon speaker settings are on for each of the speakers being used, including the sub.
- tested WITHOUT the sub speaker setting being 'on' (a suggestion I found online).
- tested audio output using different input sources (sat/tuner/bluray/pandora, etc). None of them result in sound from the speakers, but all of them will generate audio to the TV speakers once the HDMI audio setting is switched to TV from AVR.
- unplugged all the speakers from the module and tested them each independently. Nothing.
So I'm kinda stuck. I understand the Acoustimass system ignores the processed audio signal from the Denon. It just takes the raw audio and re-processes it itself. But it seems like it's just ignoring it altogether. Not sure how to fix that.
A couple of things worth mentioning...
The sub is laying on its side in a cabinet. The owners manual says this is okay. Even if it's not okay, I had it sitting upright on the floor outside that cabinet during troubleshooting. It made no difference.
Bose provides their own speaker wires for the system with RCA plugs on the sub module side, and soldered wire ends on the speaker side. Since my parents' place has the room pre-wired for surround sound, I used the existing wires in the walls and connected the Bose ends to them. It's a simple pos/neg braided wire connection. I used wire nuts to connect them and wrapped in electrical tape for protection. I also tested all four of them for connectivity -- they passed. The center channel uses the Bose-supplied cable, uncut.
I know that's a lot of information. But I figure if someone's going to be able to help me, they're going to need all of that. I would gladly wire a far superior set of speakers directly to the receiver, but alas, those aren't the speakers I'm dealing with here. I'm just about out of ideas. I appreciate any input someone may have.
Paul
#2 of 8 schan1269
schan1269
    HTF Expert
  • 13,174 posts
  • Real Name:Sam
Posted May 01 2014 - 03:25 PM
So, like the instructions say...
You have the proprietary wire connected from the Denon to the bass module*.
The 5 cubes run to to the bass module*.
Denon set 5.0.
*The bass module is not a subwoofer. Nothing acoustimass should be confused as such.
#3 of 8 pmantey
pmantey
  • 2 posts
Posted May 02 2014 - 01:14 PM
Sam,
Thanks for the semantical clarification. But I don't have 5.0 or 5.1. If a person were to refer to the bass module as a subwoofer (which I did, apparently erroneously), then I have 0.1. But if the bass module is not a sub, then I have 1.0? (presumably -- again left to semantical clarification).
Bottom line is the speakers in the bass module work. None of the others are emitting any sound. Everything is hooked up as per the directions and your instruction. I suspect, as one person suggested to me, that I have a defective unit. May be time to return the Acoustimass system for something better (and even possibly less expensive).
Edited by pmantey, May 02 2014 - 01:17 PM.
#4 of 8 schan1269
schan1269
    HTF Expert
  • 13,174 posts
  • Real Name:Sam
Posted May 02 2014 - 03:31 PM
Good plan.
#5 of 8 Jason Charlton
Jason Charlton
  • 2,860 posts
  • Real Name:Jason Charlton
  • LocationBaltimore, MD
Posted May 03 2014 - 07:24 AM
Actually, I think you'll be surprised at how many options you will find that outperform the Bose AND are less expensive. :)
Are you new to the Home Theater Forum? Stop by the New Member Introductions area and introduce yourself! See you there!
#6 of 8 ArmSC
ArmSC
  • 136 posts
  • Real Name:Tony
  • LocationCoastal SC
Posted May 03 2014 - 11:52 AM
You already have a nice AVR with that Denon 400 so all you need now is nice set of speakers to go with it.  I'm not sure how much you payed for the Bose but retail has it around $1000.  I know you could get something that sounds great for this price or even half as much.  Now you just have to go speaker shopping...sounds like fun to me.
#7 of 8 Todd H
Todd H
    Go Dawgs!
  • 2,048 posts
  • Real Name:Todd
  • LocationGeorgia
Posted May 03 2014 - 04:09 PM
Dump the Bose on eBay and get decent speakers.
#8 of 8 John Garcia
John Garcia
    Executive Producer
  • 11,528 posts
  • Real Name:John
  • LocationNorCal
Posted May 05 2014 - 08:55 AM
Return them for sure.
HT: Emotiva UMC-200, Emotiva XPA-3, Carnegie Acoustics CSB-1s + CSC-1, GR Research A/V-1s, Epik Empire, Oppo BDP-105, PS4, PS3,URC R-50, APC-H10, Panamax 5100 Bluejeans Cable
System Two: Marantz PM7200, Pioneer FS52s, Panasonic BD79
(stolen) : Marantz SR-8300, GR Research A/V-2s, Sony SCD-222ES SACD, Panasonic BD-65, PS3 60G (250G)
Everybody is a genius, but if you judge a fish by its ability to climb a tree, it’ll spend its whole life believing that it is stupid.” – Albert Einstein
