Jump to content
Recommendation for a receiver
Receiver Speaker
Best Answer schan1269, May 03 2014 - 03:00 PM
Here is my suggestion.
3 pairs of BIC DV62 (usually around $110/pair)
BIC DV62clrs or DV52clrs(if you don't have room for the 62)...$120/$75.
Leaves enough for a Dayton Sub1000/1200
You have, literally...
No other options.
Go to the full post
  • Please log in to reply
19 replies to this topic
#1 of 20 OFFLINE   Llappin
Llappin
  • 123 posts
Posted April 27 2014 - 02:35 PM
Hello experts,
I hope you can help me find a suitable sound system for my needs and budget.  I am looking for a decent 7.1 or 7.2 receiver & speaker set around $1000. I have a 3D TV and next year I plan to upgrade to UHD, UN55HU8550.  I don't have a dedicated HT room.  My living/TV room is 11 x 15 feet and I have many neighbors around.  What I really care about is to have realistic sounds.  It doesn't have to be loud.
Last year I was thinking about Onkyo TX-NR709 but that is discontinued. Also, I am not sure if the receiver has to be compatible with 3D or UHD or HDMI 2.0. It seems HDMI 2.0 is the connector in UHD specification.  All of these questions are making it difficult for me to find something.
I look forward to your recommedations. Thank you
Llappin
#2 of 20 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,825 posts
  • Real Name:Sam
Posted April 27 2014 - 03:17 PM
The 709 was discontinued(like everything else from then...everybody else's AVR, TV, BD, DVD, shoes, cars) 3 years ago.
The "new" HDMI 2.0 is trickling now. Nobody has their whole line out yet.
The difference(relevant to UHD) from 1.4 to 2.0?
4K/60fps support.
Also, $1000 isn't nearly enough.
Here is your best featured...at the price, 7 channel 2.0 AVR.
http://www.amazon.co...rds=onkyo nr636
#3 of 20 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,825 posts
  • Real Name:Sam
Posted April 27 2014 - 03:27 PM
There is this one...(just released)...
http://www.amazon.co...neer vsx-1024-k
And(this has been out a month...and has "used" already)...
http://www.amazon.co...eywords=rx-v577
#4 of 20 OFFLINE   DennisBassi
DennisBassi
  • 132 posts
  • Real Name:Dennis
  • LocationPhoenix, Arizona
Posted April 27 2014 - 08:49 PM
Don't know if you have a Fry's Electronics in your area, but through 5/1 they have an in- store special on the Yamaha RX-V577 for $299. That would be a good start on your budget.
#5 of 20 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,825 posts
  • Real Name:Sam
Posted April 28 2014 - 06:31 AM
I wonder how Fry is selling at that price point.
#6 of 20 OFFLINE   Llappin
Llappin
  • 123 posts
Posted May 03 2014 - 09:03 AM
Hello all,
Thank you very much for all your input. Your feedback is very valuable to me. I checked the suggested receivers and they are all compatible with UHD. Now comes the hard question, what is your recommendation for a set of decent but not expensive speakers?  Please let me know if this question has been answered in a previous thread or if I should post this to another forum.  Thank you
I know this is hard question because I read in a thread that speakers are more important than receivers.  Nevertheless I am hoping that you can recommend something in the range $600.  Thank you
Llappin
#7 of 20 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,825 posts
  • Real Name:Sam
Posted May 03 2014 - 09:15 AM
$600 for 2?$600 for 5?$600 for 5.1?$600 for 7.1?(And yes, I know your goal "is $1000", which is ridiculous. You are planning UHD, and unless your planned TV is a shitty Hisence...)
#8 of 20 OFFLINE   Llappin
Llappin
  • 123 posts
Posted May 03 2014 - 02:55 PM
okay, I get it you don't think $600 is enough for speakers.
#9 of 20 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,825 posts
  • Real Name:Sam
Posted May 03 2014 - 03:00 PM   Best Answer
No other options.
#10 of 20 OFFLINE   Llappin
Llappin
  • 123 posts
Posted May 03 2014 - 03:08 PM
Thank you Sam, :) I really really appreciate this.
#11 of 20 OFFLINE   Llappin
Llappin
  • 123 posts
Posted May 03 2014 - 03:16 PM
Hi again,
I just checked the speakers on amazon.  Do you think that I could replace one of the pairs with BIC America Venturi DV64 2-Way Tower?
#12 of 20 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,825 posts
  • Real Name:Sam
Posted May 03 2014 - 03:19 PM
Hi again,
Sure. Is it going to stay under your $600?
The DV64 is priced each...not pair.
#13 of 20 OFFLINE   Llappin
Llappin
  • 123 posts
Posted May 03 2014 - 03:25 PM
I can raise my budget by a couple of hundred dollars.  They will fit better on each side of the TV.  Thank you again
#14 of 20 OFFLINE   Llappin
Llappin
  • 123 posts
Posted May 03 2014 - 03:46 PM
Hi Sam,
Amazon has listed BICHT8C 8-inch for $59.99. Do you think that is a good option for that price? I know I will have to spend more money to have them installed but it may be worth it.  I am not sure why they went from $199 to $59.99.
#15 of 20 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,825 posts
  • Real Name:Sam
Posted May 03 2014 - 05:57 PM
If you need in-Wall.
#16 of 20 OFFLINE   Llappin
Llappin
  • 123 posts
Posted May 04 2014 - 04:57 PM
I just selected the following and they are in my Amazon shopping cart all I have to do to go to checkout. I ended up spending more than $600 but that was to be expected.  If anyone has any feedback good or bad please let me know.  Thank you
Receiver: Onkyo TX-NR636 7.2-Channel
Speakers:
2 - BIC America HT8W 8-Inch 3-Way Acoustech Series In-Wall Speakers
2 - BIC America Venturi DV64 2-Way Tower Speaker
1 - BIC America DV-62CLRS 6-Inch 2-Way Center Channel
1 - Dayton Audio SUB-1000 10-Inch 100 Watt Powered Subwoofer
The front and side speakers are 2-way but the surrounds are 3 way.  I hope that doesn’t represent a problem
#17 of 20 OFFLINE   diceman1000
diceman1000
  • 65 posts
Posted May 09 2014 - 07:09 PM
Here is my suggestion.3 pairs of BIC DV62 (usually around $110/pair)BIC DV62clrs or DV52clrs(if you don't have room for the 62)...$120/$75.Leaves enough for a Dayton Sub1000/1200You have, literally...No other options.
I have alnost this exact setup except I run Dayton B652s for surrounds with an H/K AVR1700 running everything and it sounds great for movies and music. Might I suggest an H/K AVR1710 with BIC Formula series speakers
#18 of 20 OFFLINE   Llappin
Llappin
  • 123 posts
Posted May 11 2014 - 03:08 PM
Hi,
I actually placed my order just after my last post.  HK AVR 1710 sounds nice but it doesn't have HDMI 2.0 to handle UHD.  I am planning on getting a UHD TV next year and if I understand it correctly the receiver should be to handle the signal.
#19 of 20 OFFLINE   diceman1000
diceman1000
  • 65 posts
Posted May 12 2014 - 07:37 AM
Hi,I actually placed my order just after my last post. HK AVR 1710 sounds nice but it doesn't have HDMI 2.0 to handle UHD. I am planning on getting a UHD TV next year and if I understand it correctly the receiver should be to handle the signal.
Cool, and yes, your AVR needs to be able to handle the signal. Congrats on the new purchase, I absolutely love my BIC/Dayton combo.
#20 of 20 OFFLINE   MatthewJones
MatthewJones
    Extra
  • 19 posts
  • Real Name:Matthew
Posted May 12 2014 - 09:45 PM
My suggestion would be:
[font="arial, helvetica, sans-serif;"]Sony 470W Mini-HiFi System with iPod/iPhone Dock :) [/font]
[font="arial, helvetica, sans-serif;"]Go for it and it would suit your budget too! [/font]
