Jump to content
Sony SA-W552 FL output problem
  • Please log in to reply
2 replies to this topic
#1 of 3 OFFLINE   sekicz
  • 2 posts
  • Real Name:Jiří
Posted April 14 2014 - 08:46 AM
Hi there,
I have found in our second house Sony SEN-R5520 (SAW553+HCD551). When I have connected everything is okay but something (probably on amp) is wrong with front left speaker output - i have tried to change speakers and all cables but on leftfront speaker when i mute the sound you can hear electronic noise with a little volume from tuner and its last preset.
Can somebody here help me? Thanks.
#2 of 3 OFFLINE   John Garcia
John Garcia
    Executive Producer
  • 11,571 posts
  • Real Name:John
  • LocationNorCal
Posted April 16 2014 - 09:12 AM
Are you saying you swapped the right and left speaker?  Try that if not.  If the problem follows the speaker, it is obviously the speaker.  If the problem stays on the left side, it is the receiver/amp.  It also may seem obvious, but if there is a balance control, make sure it is set properly - I've done that too.
The sound you hear when you mute is "crosstalk" in the PCB from the tuner.
HT: Emotiva UMC-200, Emotiva XPA-3, Carnegie Acoustics CSB-1s + CSC-1, GR Research A/V-1s, Epik Empire, Oppo BDP-105, PS4, PS3,URC R-50, APC-H10, Panamax 5100 Bluejeans Cable
System Two: Marantz PM7200, Pioneer FS52s, Panasonic BD79
(stolen) : Marantz SR-8300, GR Research A/V-2s, Sony SCD-222ES SACD, Panasonic BD-65, PS3 60G (250G)
Everybody is a genius, but if you judge a fish by its ability to climb a tree, it’ll spend its whole life believing that it is stupid.” – Albert Einstein
#3 of 3 OFFLINE   sekicz
  • 2 posts
  • Real Name:Jiří
Posted April 17 2014 - 02:35 AM
Hi. I've cleaned the amp pcbs (its in superwoofer part) from dust (hell of a dust after 20 or so years). And outputs are okay atm. But now I have few problems with pre amp (i am thinking that it is worn capacitors) because when I lower volume to 0 I can still hear music playing with crappy quality, and also now I can hear more electrical noise from speakers and eg. when i turn on the system cd changer is checking for cds and i can hear that in speakers...
