Home Automation w/Video and Audio (1 Viewer)
John Shepherd
Hi guys,
Really happy to have found these forums! I am in the process of building a new home, and the builder has thrown in the rough-in for Control4 home automation. At it's core and what I'm most interested in discussing is:
- Speakers throughout house.
- TV/Video in multiple rooms.
- Home Theater.
All wires for the home run to a central location. All wires for Home Theater run off to storage area right behind the theatre room.
Now I've received a quote on the Control4 set-up, and I'm curious with the current rough in if there are other options I should consider out there that are potentially cheaper? And potentially even nicer and more consumer friendly to set-up.
I've seen things like:
Sonos for audio.
Smartthings for home automation (which doesn't charge you a subscription for managing your home via smartphone away from the house).
But I haven't really seen anything for managing video well. Any ideas or helpful sites that you would recommend?
Thanks.
Shep
schan1269
HTF Expert
Chicago-ish/NW Indiana
Sam
Control4, Elan and the many others...
It depends on how you like, or dislike, the user interface.
Whoever your builder is using for this install, they should have a working mock-up somewhere.
schan1269
HTF Expert
Sam
By the way...
I did the theater and audio system design in a house that is using Elan. This homeowner went nuts. Buying a washer that can tell you when you need to buy detergent. A fridge that has internal scanning to tell you when you need milk.
The "added extra cost" of the Elan?
$157,000...(and yes...that is just the home automation)
The house even goes into a low power mode when no-one is home.
papill6n
