Jump to content
Subwoofer not woofing! Help
  • Please log in to reply
51 replies to this topic
#1 of 52 OFFLINE   cbrown3301
cbrown3301
    Extra
  • 22 posts
  • Real Name:chad
Posted February 23 2014 - 11:11 AM
I have a kenwood powered sub, old (SW-32HT), that will turn on but the sound is beyond weak. I took it apart and all the fuses are ok, all connections are good. There are no tears in the speaker material. Thats the extint of my knowledge of home theatre powered subwoofers. Any ideas or options I can try to fix this. My guess is maybe the amplifier isnt working that is attached to the unit but not sure how to test that.
#2 of 52 OFFLINE   schan1269
schan1269
    HTF Expert
  • 14,943 posts
  • Real Name:Sam
Posted February 23 2014 - 02:21 PM
Try another driver.If the amp is dead, time for a new one. Not sure if the driver in that one is worth turning the sub passive(ie, bypassing that amp, buying another amp. HTD sells sub specific amps)
#3 of 52 OFFLINE   Tom Vodhanel
Tom Vodhanel
  • 2,203 posts
Posted February 23 2014 - 02:29 PM
 What type of receiver  / processor are you using and how do you have it connected to the subwoofer?
 Tom V.
#4 of 52 OFFLINE   cbrown3301
cbrown3301
    Extra
  • 22 posts
  • Real Name:chad
Posted February 23 2014 - 03:14 PM
A kenwood vr-407. the sub is a powered sub and plugs into the reciever
#5 of 52 OFFLINE   cbrown3301
cbrown3301
    Extra
  • 22 posts
  • Real Name:chad
Posted February 23 2014 - 03:17 PM
Try another driver.....sorry i am not sure what you mean. I am a novice at best but very DYI so if there is a way to fix it I want to try. Thanks for any help you can pass my way.
#6 of 52 OFFLINE   schan1269
schan1269
    HTF Expert
  • 14,943 posts
  • Real Name:Sam
Posted February 23 2014 - 03:18 PM
New, to you?Or been in use awhile...and the sub not working Is a new occurrence?
#7 of 52 OFFLINE   Edwin-S
Edwin-S
    Producer
  • 5,727 posts
Posted February 23 2014 - 03:33 PM
He is saying to try replacing the speaker, because you may have a weak or bad voice coil in it. If a new speaker does not improve the sound then it is most likely a tired amp. This is assuming that you have eliminated any possibility of a bad cable or receiver problem. Do you have another receiver you can try to make sure that your subwoofer output on your current receiver hasn't turtled? I'd eliminate those possibilities before starting to buy parts.
"You bring a horse for me?" "Looks like......looks like we're shy of one horse." "No.......You brought two too many."
#8 of 52 OFFLINE   cbrown3301
cbrown3301
    Extra
  • 22 posts
  • Real Name:chad
I bought it original, long time ago. Just noticed that the sub was not banging very hard anymore so decided to see if I could get it to work again.
#9 of 52 OFFLINE   cbrown3301
cbrown3301
    Extra
  • 22 posts
  • Real Name:chad
Posted February 23 2014 - 03:41 PM
I dont have another reciever to hook the sub up to. The reciever seems to work fine with the other speakers it powers( two side, one center, and two surround). when I set the reciever to put out just to the sub, the sub speaker will produce some muffled bass sound and move some air but thats it. Reminds me of when a car sub acted when i didnt have an amp powering it so thought the subs amp might have craped out. So speaker might be ok but not sure how to hook another amp to it.
#10 of 52 OFFLINE   Edwin-S
Edwin-S
    Producer
  • 5,727 posts
Posted February 23 2014 - 03:46 PM
The speaker coil may be worn out. Might be worth trying another speaker like he mentioned.
#11 of 52 OFFLINE   cbrown3301
cbrown3301
    Extra
  • 22 posts
  • Real Name:chad
Posted February 23 2014 - 03:59 PM
So with the speaker responding even though it is weak means the amp is probably ok but the sub speaker coil is shot, is that correct.
#12 of 52 OFFLINE   Edwin-S
Edwin-S
    Producer
  • 5,727 posts
Posted February 23 2014 - 04:18 PM
It's possible, but I'm not going to say that that is the only answer. It could still be an amp issue. Replacing the speaker driver would help you pinpoint the problem. If the problem disappears with a new driver then it was most likely a coil problem. If not, then there is a problem in the amp. Doing it that way could get expensive, because if you spring for a new driver and it turns out to be the amp then you are stuck deciding to buy a new amp as well or throwing in the towel and just replacing the entire unit.
Do you have a local stereo shop or electronics repair shop? Might pay to take it in and have them check the output of the amp with an oscilloscope. If the output is good then you would know that it has to be the speaker driver. Either way, it would probably be cheaper to have the amp checked out at an electronics shop than to buy a new driver, only to find out that the amp really was the problem.
#13 of 52 OFFLINE   schan1269
schan1269
    HTF Expert
  • 14,943 posts
  • Real Name:Sam
Posted February 23 2014 - 04:21 PM
Take one of your other 5(preferably not the center)...Set the sub crossover in the Kenwood to 200hz. Take speaker wire. Connect to the amp. One of your other 5 speakers will siffice for 10 seconds.
#14 of 52 OFFLINE   Edwin-S
Edwin-S
    Producer
  • 5,727 posts
Posted February 23 2014 - 04:39 PM
Ha ha. I'll have to try to remember that if I ever have a problem with my subwoofer amp.
#15 of 52 OFFLINE   cbrown3301
cbrown3301
    Extra
  • 22 posts
  • Real Name:chad
Posted February 23 2014 - 05:42 PM
I will have to change the hook up for one of the other speakers. The sub is a three prong plug in that goes to the amp im guessing then the other end clips onto the sub speaker, where as the other speakers the wires just clip  in, one positive one negitive on the back of the speaker
#16 of 52 OFFLINE   schan1269
schan1269
    HTF Expert
  • 14,943 posts
  • Real Name:Sam
Posted February 23 2014 - 06:01 PM
The bottom pick...Are those the leads pulled off the driver?If yes, hook the speaker wire from your closest speaker. The two there is irrelevant(all you are doing is 10 seconds to know if the coil is dead, or the amp is.
#17 of 52 OFFLINE   cbrown3301
cbrown3301
    Extra
  • 22 posts
  • Real Name:chad
Posted February 23 2014 - 06:08 PM
The bottom pick.... are off the driver. Any idea which the positve terminal is, orange or grey?
#18 of 52 OFFLINE   schan1269
schan1269
    HTF Expert
  • 14,943 posts
  • Real Name:Sam
Posted February 23 2014 - 06:11 PM
The double is positive, but is irrelevant for this 10 second test.
#19 of 52 OFFLINE   cbrown3301
cbrown3301
    Extra
  • 22 posts
  • Real Name:chad
Posted February 23 2014 - 06:32 PM
Not sure i understand, you want me to hook another speakers wire, ie my left front, to the orange and grey from the amp to see if it powers my left front....?
#20 of 52 OFFLINE   cbrown3301
cbrown3301
    Extra
  • 22 posts
  • Real Name:chad
Posted February 23 2014 - 06:47 PM
Ok this is what i did, i just took my front Left wires and put them onto my sub and the sub worked better then it did with the powered amp so i guess the amp is fried does that sound right?
