Hello all!
I'm new to the forum! Finally after some research I found this community cause its difficult to find experts.
I have a home theater system connected in my room with proper cables and everything. I never had any trouble until recently... I have a Klipsch system, I have the RSX-4 monitors, the RS-25 center speaker and the RW-8 Subwoofer all of bought brand new back like in 2007, all of them connected to the Yamaha RX-V2090 Stereo Receiver one of the best receivers ever built! Old but gold.
Everything works perfectly, like I said until recently. one day I turned on my system and the subwoofer goes "booooooooo" lowering pitch, then it just won't turn on. I checked the fuse and its completely burnt. Took it to the nearest repair center and they "fixed" it in about two weeks, charged me with USD$100. They told me the power supply was burnt and had to be replaced also some voltage regulators. Plugged it once again and it worked!
Until yesterday !!! It died again the same way, and the fuse burnt!!... I had a spare fuse, tried it and it burnt it! I have 90 day warranty for the repair so I guess I'm going to go over there again.
What could be happening to my woofer??
Some additional info:
The subwoofer, the receiver, a desktop pc, a simple lamp, a 42" LCD TV and maybe something else are connected to a Voltage Regulator or stabilizer or something like that, it looks like this:
It has a fuse and supposedly it regulates voltage. The subwoofer was always set to ON and whenever I turned on the Stabilizer the woofer turned on (maybe this has to do?) maybe I have lots of things connected to that thing ? Any ideas?
I'll be very grateful if someone can enlighten me!!
