How do I connect Sony Bravia to DAV-DZ660 Home Theatre (1 Viewer)
iZ wonderboy
Simon
Hello
I have a Sony Bravia Tv, Model no: KDL - 42W805A
and also have a home theatre : DAV - DZ660
I only just bought the home theatre, and I have problems connection it to the TV, channel wise.
I use a HDMI cable to connect the two devices but there seem to come no sound out of the speakers once I change to the tv channels. And yes, I can hear it if I just change it over to the HDMI input.
If anyone could help me, that would be appreciated!
iZ wonderboy
Simon
Toslink is like the optical cable? But I understood it as if I could just use the HDMI or the Optical Cable.
iZ wonderboy
Simon
I'll try to buy a Optical Cable, because apparently the HDMI is only for the video, but not the sound.
Thanks for Help Sam!
Ciao
CoolMovies
