Jump to content
Sign up for a free account!
Signing up for an account is fast and free. As a member you can join in the conversation, enter contests and you won't get the popup ads that guests get. Click here to create your free account.
Help! 5.1 humming noise
  • Please log in to reply
7 replies to this topic
#1 of 8 senorpip
senorpip
  • 3 posts
  • Real Name:Chris
Posted November 09 2013 - 10:27 AM
Hello,
I have a new 5.1 system connected to my TV. I have definitive technologies speakers (front left/right, center and 2 surrounds) and a pioneer vsx 525 AV receiver. It works fine in terms of sound production (actually it sounds great!) except there is this terrible buzz/hum sounds that comes out of the front left/right and center speakers whenever the receiver is turned on. The surrounds are fine. It is always a constant decibal level and doesn't matter what volume I have the receiver set at. I have read a lot about ground loops and while I don't entirely understand it, I have tried a few steps to see if thats the problem - disconnected the Verizon Fios box/wire, disconnected various HDMI, etc... However, nothing seems to make the buzz stop. It is present on all input settings on the receiver (Sat/Cbl, DVD, game, etc...).
Any advice on what to do? Is it a problem with my receiver? My speakers?
Thanks!
#2 of 8 schan1269
schan1269
    HTF Expert
  • 13,162 posts
  • Real Name:Sam
Posted November 09 2013 - 10:58 AM
Are you using a separate sub?
What is the crossover? Ground loops are 60hz. So it should only be the subwoofer in your system...unless you don't have one.
#3 of 8 senorpip
senorpip
  • 3 posts
  • Real Name:Chris
Posted November 09 2013 - 11:21 AM
Yes I have a sub that came with the speakers. It is attached to the receiver. All speakers are attached directly to the receiver as are all components with one single hdmi out going to the TV.
As for "crossover" I'm sorry I don't know what that means
#4 of 8 schan1269
schan1269
    HTF Expert
  • 13,162 posts
  • Real Name:Sam
Posted November 09 2013 - 12:10 PM
Crossover is in the bass management.
Bass management is the entire point of buying an AVR.
#5 of 8 senorpip
senorpip
  • 3 posts
  • Real Name:Chris
Posted November 09 2013 - 12:20 PM
Ok so any ideas on what I can do regarding the issue. Does it have something to do with my sub? I've tried unplugging and disconnecting it but that doesn't change anything.
#6 of 8 schan1269
schan1269
    HTF Expert
  • 13,162 posts
  • Real Name:Sam
Posted November 09 2013 - 12:31 PM
So...
What are the speakers themselves?
What crossover did you choose?
Are you using a shielded subwoofer cable?
Is the sub connected to the same circuit as everything?
Can't help you unless you understand those questions.
#7 of 8 iluvgr8tdeals
iluvgr8tdeals
  • 2 posts
Posted November 16 2013 - 03:40 PM
Try and check on 'ground loop isolator' on Amazon. A friend of mine purchased a simple system and it had the annoying '60 hz buzz' and we installed this product, the TII ground loop isolator. It stopped the buzz. Good luck!
#8 of 8 iluvgr8tdeals
iluvgr8tdeals
  • 2 posts
Posted November 16 2013 - 03:41 PM
