Jump to content
n i connect 7.1 analog in a 6.1 analog input
  • Please log in to reply
7 replies to this topic
#1 of 8 OFFLINE   dano582
dano582
    Extra
  • 20 posts
  • Real Name:daniel barreto
Posted October 16 2013 - 04:05 PM
Hello I have a Sony str-da2es receive which has 2 multi channel analog inputs a 5.1 and 6.1 if I get a bluray player with with 7.1 analog outputs can I connect it to the 6.1 input? Also my bluray is a Sony s300 if I hook it up via the 5.1 analog will the player be doing the decoding? I ask cause I hooked it up there other day with some cheap o av cables just to try it and I was getting sound but the multi channel decoding light on there receiver would not light up or the Dolby digial logo on there display of the receiver. Thanks for any help
#2 of 8 OFFLINE   schan1269
schan1269
    HTF Expert
  • 13,881 posts
  • Real Name:Sam
Posted October 16 2013 - 08:30 PM
Yes you can connect multi-channel from 7.1 to 6.1, just do the setup.
Yes the BD player is doing the decoding.
#3 of 8 OFFLINE   dano582
dano582
    Extra
  • 20 posts
Posted October 17 2013 - 01:04 PM
By that do you mean the bluray player will have an option to output 6.1 thru the 7.1 output?
#4 of 8 OFFLINE   schan1269
schan1269
    HTF Expert
  • 13,881 posts
  • Real Name:Sam
Posted October 17 2013 - 01:13 PM
Well, after I read the manual for the S300(cause you owned it, assumed you were correct) and it has a 6channel, not 8channel. So you questions are moot.
#5 of 8 OFFLINE   dano582
dano582
    Extra
  • 20 posts
Posted October 17 2013 - 02:10 PM
Sorry for the mix up my s300 has a 5.1 analog but Im about to get a sacd player so I will need to use the 5.1 analog input on there receiver which only leaves me with the 6.1 input . I'm thinking of getting the Sony s2000 bluray which has analog output but I believe it has 7.1 analog output . That's why I was asking if I can connect the 7.1 out to the 6.1 of the receiver and connect the sacd to the 5.1 input
#6 of 8 OFFLINE   schan1269
schan1269
    HTF Expert
  • 13,881 posts
  • Real Name:Sam
Posted October 17 2013 - 02:18 PM
The S2000 doesn't have an 8channel either. It is 6.
#7 of 8 OFFLINE   dano582
dano582
    Extra
  • 20 posts
Posted October 17 2013 - 02:45 PM
your right about that sorry its the s550 that has 8 channel out I been looking at 3 models the s500 s550 and then s2000 I know they are all old players but I want something heavy and with high end build quality! I don't care about streaming or anything like that I just want a player with analog out that will give me Dolby HD and dts master decoding . Any advice on which one I should get? Oh and that plays all blurays I tried to watch my clint eastwoods man with no name trilogy and it didn't work on my s300
Edited by dano582, October 17 2013 - 02:47 PM.
#8 of 8 OFFLINE   schan1269
schan1269
    HTF Expert
  • 13,881 posts
  • Real Name:Sam
Posted October 17 2013 - 03:49 PM
I just looked at the S550 manual online(you know, manuals are available on the interwebs).
It appears the S550 is "rear surround" on or off. There is no option for a "single" rear speaker. I doubt the 500 has that option either. If you want, go download the manual.
Since Sony doesn't offer that option, I have no idea if any other BD players with analog that allow a single rear speaker.
But to answer your question, yes you can connect one of the two to your AVR...you'll miss one channel of information.
Your simplest...and less expensive, option is to replace that AVR with a newer one. SACD/DVD-A over HDMI is common now and is less expensive than what you are attempting to accomplish.
