sonofatalker
- Aug 13, 2013
- Scott
[email protected]
Get powerful, hard-hitting bass from a remarkably compact subwoofer. Velodyne, one of the world's leading subwoofer companies for over 20 years, brings you the SPL-1000R, part of their acclaimed "Small Plays Loud" Series of powered subs. Measuring just a shade over a one-foot cube, this mighty mite features a 10" woofer and a potent 1,000-watt amplifier that are sure to handle even the most challenging low-frequency passages from your movies and music. And this sub even comes with a remote control, so you can adjust the bass output without getting up from your favorite listening chair.
The 10" woofer is mounted in a rock-solid die-cast aluminum basket and features Velodyne's exclusive "Dynamic Driver Control System," which assures linear woofer movement and greatly reduces distortion. This advanced sub also includes embedded computer chips called DSPs (Digital Signal Processors) that monitor the audio functions of the subwoofer. It's like having your bass controlled with the accuracy of a high-speed computer. The result is louder, lower, and more precise bass performance.To ensure that you're getting the best possible sound for your specific listening room, the SPL-1000R comes with a Room Bass Correction system that automatically calibrates the sub's low-frequency response to the acoustics of your room. Just plug in the included microphone, place it in your favorite listening chair, and hit the "EQ" button on the remote. It's that easy.
[email protected]
