Jump to content
Sign up for a free account!
Add Subwoofer to Basic System
  • Please log in to reply
10 replies to this topic
#1 of 11 pk&k
pk&k
  • 8 posts
  • Real Name:Tim
Posted August 18 2013 - 10:09 AM
Hi All,
We have a Bose Wave Radio that we are using for our HDTV, which provides adequate sound.  I would like to somehow add a subwoofer, though, as I am a bass-lover.  Is there a relatively inexpensive way to do this?
You can probably tell I am a newbie :D
#2 of 11 schan1269
schan1269
    HTF Expert
  • 12,827 posts
  • Real Name:Sam
Posted August 18 2013 - 10:48 AM
Depends on what connection you are using between the TV and B-WR. (I've never looked at a B-WR, so I don't even know what connections it has)
But yes, splitting your audio output and running it to the B-WR and a separate sub is possible. They'll just have separate volumes to adjust.
#3 of 11 Tom Vodhanel
Tom Vodhanel
  • 2,178 posts
Posted August 18 2013 - 07:26 PM
Hi All,
 Probably not the answer you are looking for---BUT:
 I'd retire the bose to a secondary system(kitchen, bedroom, etc) and start with a basic component 2.1 system for your main viewing area. An entry level receiver, pair of decent book shelf speakers, and a good $200-300 sub will set you back $500-600. But now you have the foundation for a respectable 5.1 system down the road AND the currently "2.1" performance will be magnitudes better than what you have now imo.
 Tom V.
#4 of 11 pk&k
pk&k
  • 8 posts
  • Real Name:Tim
Posted August 21 2013 - 11:55 AM
Thanks.  Would it be worth maybe going with something like this instead?
http://www.amazon.co... theater system
#5 of 11 schan1269
schan1269
    HTF Expert
  • 12,827 posts
  • Real Name:Sam
Posted August 21 2013 - 12:06 PM
Or the 5500. There is nothing "wrong" with the 3500. It just uses a passive sub.
But, will it outperform the B-WR?
Absolutely.
#6 of 11 pk&k
pk&k
  • 8 posts
  • Real Name:Tim
Posted August 21 2013 - 12:07 PM
What's a passive sub?
#7 of 11 schan1269
schan1269
    HTF Expert
  • 12,827 posts
  • Real Name:Sam
Posted August 21 2013 - 12:10 PM
Means the AVR powers it.
Vs the 5500 coming with a self-powered sub.
#8 of 11 Al.Anderson
Al.Anderson
  • 2,129 posts
  • Real Name:Al
Posted August 21 2013 - 02:39 PM
And since most receivers support powered subs, and most subs are powered, if you even want to upgrade that 3500 or replace a defective piece, you'll be hard pressed to do so.  But if it's an interim solution, or you just want to save a few bucks, as Sam said there's nothing wrong with the 3500.  (Especially for the price.)
#9 of 11 pk&k
pk&k
  • 8 posts
  • Real Name:Tim
Posted August 22 2013 - 12:17 PM
Isn't the s5500 7.1 though? Would the S6500 be a good choice?  I want it to sound great, but not break the bank.
#10 of 11 Al.Anderson
Al.Anderson
  • 2,129 posts
  • Real Name:Al
Posted August 22 2013 - 12:35 PM
Looking at the Onkyo site, the 6500 has a network connection, has more HDMI connections, and has an out put for a zone 2 (but needs another amp to use it); the 5500 has discrete amps, a wood cabinet and is cheaper.
As for the 7.1, you can just not attach the rear speakers, not a big deal.  All decent amps let you turn off channels you aren't using.
I didn't read the manual, but I like network connectivity; but if I were trying to save a few bucks I'd go with the 5500, since most network features can be had one other components (like s media device or a BD/DVD).
#11 of 11 schan1269
schan1269
    HTF Expert
  • 12,827 posts
  • Real Name:Sam
Posted August 22 2013 - 12:37 PM
I don't "keep track" of pre-package systems. I was merely moving up the numbers.
