Jump to content
Will Audiosource AMP -100 be enough to power my Heights
Best Answer schan1269, August 13 2013 - 11:11 AM
If you are picking up noise, put composite cables in(which is the same as subwoofer cable and digital coax). Go to the full post
  • Please log in to reply
9 replies to this topic
#1 of 10 OFFLINE   sean1976
sean1976
  • 121 posts
  • Real Name:Sean H
  • LocationToronto, ON
Posted August 04 2013 - 04:15 PM
Hey all - Just looking for opinions on whether this amp ( 50 wpc @ 8ohm ) http://www.audiosour...100/tech-specs/  will be enough to power my Heights that I'm going to be adding to my set up to make it 9.2.. I've currently got 7.2 speakers,  driven with an X -4000 (125 wats x 2 channel @ 8 ohm ) .. The heights I'll be purchasing are PSB b4's with a sensitivity of 89.  The amp itself has a THD of less then 0.2 so I figure it should be good to run full power,  however I'm concerned about over driving it when listening to music in multi channel surround or Dolby PLiix + DSX Heights.
I got a great deal on it ( 30 bucks regular 170 + tax ) so worse comes to worse I can always sell it for more then I bought it for. Option 3 is to buy a matching amp and run them both bridged ( 160watts ) and have them power my Front Left and Right separately leaving the AVR amps to power the rest.  Thoughts?
"A nation of sheep will beget a government of Wolves " -
Edward R. Murrow
#2 of 10 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,705 posts
  • Real Name:Sam
Posted August 04 2013 - 05:05 PM
Your 4000, all channels driven, probably only produces around 50wpc anyway...you are good.
#3 of 10 OFFLINE   sean1976
sean1976
  • 121 posts
  • Real Name:Sean H
Posted August 04 2013 - 05:18 PM
Awesome - Thanks!
Edward R. Murrow
#4 of 10 OFFLINE   Glen B2
Glen B2
  • 42 posts
  • Real Name:Glen
  • LocationOld Mill Basin, Brooklyn, NY
Posted August 13 2013 - 10:35 AM
A single AMP 100 should work fine.  If it turns out to be not enough, just get another one and run them both bridged.  I ran three of them bridged in my party system, and they worked great.
Main System: Denon DP-59L TT, Audio-Technica AT33EV MC cartridge, Marantz Reference SA-11S2 SACD player, Classé CP-50 preamp, Classé CA-300 amp, Classé RC-1 remote interface, PSB Stratus Gold i speakers, DIY Balanced AC Power Conditioner, Acoustic Zen Cables, Oyaide and Furutech power connectors.
HT System: Toshiba DVR5SU,  laptop #1, Outlaw Audio OAW3 wireless DAC, Marantz SR19 AVR, Phase Linear 400 Series 2 amp, Axiom mains, Optimus surrounds, Audiosource 10.1EQ, Dayton 12" subs (2), Belkin PureAv PF60 line conditioner.
Party System: laptop #2, AQ Dragonfly USB DAC, Technics SUA6 preamp, Acurus A250 amp, Radio Shack 15-band EQ, Pioneer SR9 reverb amp, Cerwin-Vega DX9 speakers, Dayton exponential horns w/ HF/MF titanium compression drivers.
#5 of 10 OFFLINE   sean1976
sean1976
  • 121 posts
  • Real Name:Sean H
Posted August 13 2013 - 10:44 AM
Well it works well enough - but I've got to have the volume turned up to 100 percent during calibration to match the levels of the rest of the speakers.. I set it half way and Audyssey set it at +12 - which is the maximum,  and obviously wasn't matched properly.  Bummer is at full volume it picks up some noise of the inputs when not engaged ( so switching between speaker configs on the AVR you'll hear some feedback,  but not bad ) .. I'm keeping my eye out for another or a better one used on Kijiji FWIW - but will most likely sell this X 4000 next year and get an AVR with dedicated 9.1 amps.
Edward R. Murrow
#6 of 10 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,705 posts
  • Real Name:Sam
Posted August 13 2013 - 11:11 AM   Best Answer
#7 of 10 OFFLINE   sean1976
sean1976
  • 121 posts
  • Real Name:Sean H
Posted August 14 2013 - 01:06 PM
Thanks for the tip,  I'll try it out and let you know how it goes. Do you think this will necessitate running Audyssey again due to different cable capacitance or what not?  ie will the signal strength change when I switch cables?
Edited by sean1976, August 14 2013 - 01:18 PM.
Edward R. Murrow
#8 of 10 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,705 posts
  • Real Name:Sam
Posted August 14 2013 - 01:23 PM
How long are these cables?Under 3ft it won't make any difference.I use component(you know the video cable) between my SACD/DVD-A players and AVRs.
#9 of 10 OFFLINE   sean1976
sean1976
  • 121 posts
  • Real Name:Sean H
Posted August 14 2013 - 03:18 PM
Yup,  I know the cables you're talking about.  I took a ride out to the surplus store and got a couple:
They did the trick - the noise is gone,  bonus!!  Thanks for the advice.  As far as length goes they're 6 feet - I have no idea if they are louder or not then my other cables to be honest,  they sound about right.  I'll have to run Auddysey again just in case,  I'm curious now.  ( maybe tomorrow though I'm getting sick of running through it,  I've done it like 20 times since I bought this )
Edited by sean1976, August 14 2013 - 03:20 PM.
Edward R. Murrow
#10 of 10 OFFLINE   sean1976
sean1976
  • 121 posts
  • Real Name:Sean H
Posted August 14 2013 - 06:18 PM
Well I ran it anyways - didn't make too much of a difference,  seemed to adjust my heights by .5 lower for both the left and right,  but that could just as well be a slight variation in the mic positioning.  In any case - noise is gone,  good stuff!
Edward R. Murrow
