Jump to content
Harmony 650 - problems
  • Please log in to reply
3 replies to this topic
#1 of 4 OFFLINE   mikeabt
mikeabt
  • 82 posts
Posted July 30 2013 - 03:59 PM
All:I have had my current set up in-place for several months using the Harmony 650 as my remote of choice. Within the last couple of weeks I have noticed that the remote is having trouble communicating with the Direct TV receiver. No other devices or functions have encountered difficulties and communication to them // through them is still fine. Example: when watching TV I desire to change a channel and nothing happens. I send the same command again and the change in channel occurs. This was not a problem three weeks ago, with the receiver acting on each command flawlessly. Any ideas? I have been thinking of battery pull and reprogram of the remote but thought I would see what you folks might have to offer.Thanks to all.
#2 of 4 OFFLINE   mikeabt
mikeabt
  • 82 posts
Posted July 30 2013 - 07:46 PM
One other thing I would like to clarify: when I use the Direct TV remote I get flawless activity, so that tells me that the remote itself is the culprit. Not the systems ability to receive, transfer and transmit the commands to the individual device.
#3 of 4 OFFLINE   Type A
Type A
  • 800 posts
  • Real Name:Ty
  • LocationPortland Oregon
Posted July 31 2013 - 06:12 AM
My first thought is battery change.
JVC DLA-RS60U3D & DaLite High Power 106"
Paradigm Studio V.5 20 (5) & ADP590 (2)
Hsu VTF-2 MK3 (2) & MBM-12 MK2 (2)
Yamaha RX-A3010 & Emotiva XPA5
Oppo BDP93 & Darbee DVP 5000
*My Home Theater Photo Journal*
#4 of 4 OFFLINE   mikeabt
mikeabt
  • 82 posts
Posted August 08 2013 - 09:33 PM
Tried the battery change with no difference in results. I can see that the IR is received because there is an indicator light that glows on the connecting block. I know that the signal transfer is true when the direct TV remote is used. I think the 650 remote must be sending corrupt signal. If this is the case, what could have caused the change? I assume I could factory reset then reprogram the remote. Has anyone had similar experience to regain proper function?
