tlkaufman
- Oct 10, 2011
- Todd Kaufman
I used to have an ACER Veriton L460 mini HTPC that I had hooked up to my 46 inch Toshiba Regza HDTV...the motherboard needed replacing so as an alternative, I had a Dell GX745 desktop computer in the basement I hooked up instead. The problem I'm having is getting the screen to fill my HDTV....my Acer had an adaptor on and HDMI cord that converted? the video so that it filled the screen, but for this Dell, the adapter wasn't compatible so I purchased a cord that runs to my PC IN port on the back of the HDTV from the computer's VGA out I think. I tried playing around with screen resolution, etc and to no avail so please help a guy out!!thanks,tk
As a side note...talking to the fine folks at Best Buy and Future Shop - one told me no such cable existed to hook up this way while the other says you can order it online...a VGA to HDMI cable. I bought one and hooked it up but I get no picture at all!! lol I believe the connection on the Dell is DVI so maybe that is causing the hookup issue?
