Jump to content
Hardware for surround sound
  • Please log in to reply
4 replies to this topic
#1 of 5 OFFLINE   Goldens
Goldens
  • 2 posts
  • Real Name:Kevan
Posted July 06 2013 - 03:49 PM
I own a LG 37CS560 which has no outputs on the TV and was hoping to hook up some type of advanced sound but it seems everything wants me to go from the TV to the audio.  I thought of getting a surround sound system but most want an optical digital input, which I don't have.  I see that I can get a converter to go from coax cable to optical, but that would just be to the receiver.  Would the HDMI output from the receiver pass video signals to the TV or does anyone have a better solution?
#2 of 5 OFFLINE   schan1269
schan1269
    HTF Expert
  • 14,910 posts
  • Real Name:Sam
Posted July 06 2013 - 04:45 PM
In 99% of home theater, using an actual AVR(receiver)...You couldn't care less what outputs the TV has...unless you use Over The Air(OTA) for some of your broadcast.
#3 of 5 OFFLINE   schan1269
schan1269
    HTF Expert
  • 14,910 posts
  • Real Name:Sam
Posted July 06 2013 - 04:48 PM
A little more explanation...Your "audio system" is the brains/switching of the operation.Your TV is relegated to being a "dumb display", taking the video(only) from the AVR.
#4 of 5 OFFLINE   Goldens
Goldens
  • 2 posts
  • Real Name:Kevan
Posted July 06 2013 - 05:39 PM
So if I can find an AVR with a coax input, or convert the coax to another format I'm in business?
#5 of 5 OFFLINE   schan1269
schan1269
    HTF Expert
  • 14,910 posts
  • Real Name:Sam
Posted July 06 2013 - 06:27 PM
You missed the point. Your sources are NOT connected to the TV.They are connected to the AVR.The AVR hands the video to the TV...Meaning, it doesn't matter what the TV has/does.As an example of a speaker set that you connect your SOURCES to and it hands off the VIDEO ONLY to the TV...Onkyo HDX22 (don't remember if that is the model number, but it's close)
