Jump to content
Multi-channel networked audio switch?
Best Answer schan1269, July 06 2013 - 04:23 PM
Russound Pro-12HPThat is what you need. Not necessarily that one...but one like it. Go to the full post
  • Please log in to reply
12 replies to this topic
#1 of 13 OFFLINE   skyguy04
skyguy04
  • 14 posts
  • Real Name:Brian
Posted July 06 2013 - 09:54 AM
I'm looking for the lowest cost option to power my whole home audio system.  I have 10 rooms with 2 speakers in each, all running to a single audio panel with RCA audio connectors.  I've looked at an 8 zone amp, but it looks like that will run me about $2500.  I'm looking for alternatives.
Idea - Multi-channel networked audio switch?
Does something exist where I can control which channel to power (one at a time), either from a computer or iphone over the network?
Any suggestions would be most appreciated!
#2 of 13 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,461 posts
  • Real Name:Sam
Posted July 06 2013 - 10:18 AM
It would help to know what this "single panel with RCA connectors" is.Cause we can't help, at all, without knowing what it is.And $2500 is about right. Whole home audio is not, and never, ever, ever will be cheap.
#3 of 13 OFFLINE   skyguy04
skyguy04
  • 14 posts
  • Real Name:Brian
Posted July 06 2013 - 11:01 AM
I don't know what else to call them other than RCA connectors.  I've uploaded a photo of the panel, maybe that will help.  Basically, it's just speaker wire ran to a panel with a connector on the end.  Nothing fancy.  There is a resistor-based volume control in-line to control the volume.  Uploaded a picture of one of those as well.
Edited by skyguy04, July 06 2013 - 11:01 AM.
#4 of 13 OFFLINE   skyguy04
skyguy04
  • 14 posts
  • Real Name:Brian
Posted July 06 2013 - 11:02 AM
I don't have $2500 to spend on this project, nor do i think it's worth that much.  Surely there are other solutions than powering every speaker, all the time.
#5 of 13 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,461 posts
  • Real Name:Sam
Posted July 06 2013 - 11:14 AM
First, to cut the confusion...That is not RCA. That is binding post.Second, are all 12 sets of binding posts "live"?
#6 of 13 OFFLINE   skyguy04
skyguy04
  • 14 posts
  • Real Name:Brian
Posted July 06 2013 - 03:39 PM
hmm.. i thought binding posts were where you stick your speaker wire in the side and then twist it down tight.  These you have to actually make up a banana plug and plug them in, like i've done.  Anyhow, no biggy...
By live, do you mean powered?  Each one is literally just wire running to the back of a speaker, no power.  Only 10 of them actually run to speakers.  There are 2 more rooms that are wired, but no speakers.
Edited by skyguy04, July 06 2013 - 03:45 PM.
#7 of 13 OFFLINE   skyguy04
skyguy04
  • 14 posts
  • Real Name:Brian
Posted July 06 2013 - 03:42 PM
nevermind, you're right about the binding posts.  I just looked up RCA connectors and that's not what these are.
#8 of 13 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,461 posts
  • Real Name:Sam
Posted July 06 2013 - 04:19 PM
"Live" meant wired at the other end with a speaker...So, you've got 12 sets(10 in use) of binding posts ready for anywhere from...2 channel amp ran through a 12-way speaker switch for 12(or 10) sets of speakers. Or two 2 channel amps running through a "2 source 12-way" speaker switch...Or three 2 channel amps running through a "3 source 12-way"...And so on...
#9 of 13 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,461 posts
  • Real Name:Sam
Posted July 06 2013 - 04:23 PM   Best Answer
#10 of 13 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,461 posts
  • Real Name:Sam
Posted July 06 2013 - 04:33 PM
The 12HP is a two source. So, you could get either...Two 2 channel amps or one 4 channel and...Feed your AVR to one set(two channels) and leave the other "open" for connecting an iPad/phone/cd player, or whatever else you wanted.That way if you were doing a superbowl party you could choose to feed the game "wherever you wanted" and feed something else "everywhere else"...
#11 of 13 OFFLINE   skyguy04
skyguy04
  • 14 posts
  • Real Name:Brian
Posted July 06 2013 - 05:41 PM
Wo, thanks!  So there is no networked switch out there that you can operate from your iPhone, huh?  Doh...
It looks like my only options are pay around $400-500 for a 2-channel amp + speaker selector or $2500 for an 8 channel amp (or probably a ton more for a 12 channel amp).  Correct?
Thanks again for your help!
#12 of 13 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,461 posts
  • Real Name:Sam
Posted July 06 2013 - 06:04 PM
There are networked(actually RS 232 that "takes network and converts it") speaker switches...But they cost more than a 12 channel amp.
#13 of 13 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,461 posts
  • Real Name:Sam
Posted July 06 2013 - 06:10 PM
Put it this way. The last 14 zone, 5 source "internet controlled" system I designed...$750 for my design$2300-ish install($140 an hour, included "training the owner")$27,000 in equipment
