Jump to content
how to connect cable box, A/V receiver and TV
  • Please log in to reply
3 replies to this topic
#1 of 4 OFFLINE   vacantstare
vacantstare
  • 1 posts
  • Real Name:Dana
Posted July 04 2013 - 07:27 AM
Hello folks, I'm trying to set up an inexpensive home theater with the following components:
Panasonic Viera tc-l37s1
Sony STR-DH540
Motorola DCT 2500
Roku
I have the roku/receiver/tv part working fine, but I am not sure how to get the signal from the cable box to the tv through the receiver.
Cable box has no HDMI, and the receiver has no S-video, so I am using the rca style Video feed.
Initially, the only connection I had from the receiver to the TV was the HDMI, and that worked fine for carrying the Roku signal, but not the signal from the cable box. I worked around it by running the video RCA cable directly from the cable box to the tv, but it seems like there should be a way to pipe that signal to the receiver, then on to the tv.
Do I need one RCA cable from the cable box to the receiver, and another from the receiver to the tv?
thanks!
#2 of 4 OFFLINE   gene c
gene c
    Producer
  • 5,797 posts
  • Real Name:Gene
  • LocationBay area, Ca
Posted July 04 2013 - 08:18 AM
The Sony 540 doesn't do analog to digital video conversion so you would need a composite connection from the 540 to the display. But s-video is a better option then composite so I would use an s-video cable from the cable box to the display.
"Everyday room": Panasonic 58" Plasma, Dish HD DVR, Pioneer Elite vsx-23, BDP-23 BR, dv58avi universal dvd player, Paradigm Studio 20 V1, CC-450, Dayton HSU-10 subwoofer.
"Movie/Music room": Toshiba 65" DLP, Dish HD receiver, Marantz 7005, CC-4003, BD-7006, Polk LSI25's-LSi7's-LSiC, 2 original Dayton 10" "Mighty-Mites" subwoofers. (subject to change without notice).
Also have  MB Quart Vera VS05 +.....too much to list. Help me.
#3 of 4 OFFLINE   schan1269
schan1269
    HTF Expert
  • 16,116 posts
  • Real Name:Sam
Posted July 04 2013 - 08:29 AM
Or, call your cable company and upgrade to a HD STB.
#4 of 4 OFFLINE   Sabby
Sabby
  • 7 posts
  • Real Name:Rick
Posted July 09 2013 - 05:13 PM
You will not get high definition to the TV with S video or composite. Since your receiver does not have component video out your options are to leave it the way you have it wired or get a new cable box.I would try to get a new cable box as schan1269 suggested
