Jump to content
Pioneer VSX-56TXi receiver freezing
  • Please log in to reply
5 replies to this topic
#1 of 6 OFFLINE   edwin108
edwin108
  • 6 posts
  • Real Name:Edwin
  • LocationNew Jersey
Posted June 14 2013 - 06:27 PM
[color=rgb(0,0,0);font-family:Verdana, Arial, Helvetica, sans-serif;font-size:12px;background-color:rgb(239,239,239);]Hello, [/color]
[color=rgb(0,0,0);font-family:Verdana, Arial, Helvetica, sans-serif;font-size:12px;background-color:rgb(239,239,239);]I have a Pioneer Elite VSX-56TXi receiver that is having some problems. It freezes and cannot be turned off until I unplug it. Then, the standby light doesn't turn on when I plug it in.  I can only get it to turn on after leaving it unplugged for several hours. Also, when it freezes, it keeps playing audio.  If anyone knows of a fix, or which component could be faulty, please let me know. [/color]
[color=rgb(0,0,0);font-family:Verdana, Arial, Helvetica, sans-serif;font-size:12px;background-color:rgb(239,239,239);]Thanks[/color]
Pioneer Elite VSX-56TXi Receiver | Pioneer Elite DV-47A DVD Player
Insignia NS-HDTUNE HD Radio | Sony MXD-D40 MiniDisc Deck
Bose 901 Series I | Bose 901 Series IV (x2) | Polk Audio PSW505 Subwoofer
#2 of 6 OFFLINE   gene c
gene c
    Producer
  • 5,760 posts
  • Real Name:Gene
  • LocationBay area, Ca
Posted June 15 2013 - 01:55 PM
Is it possible to reset the receiver after it's been unplugged for a while?
1 Switch the receiver into standby.
2 While holding down the front panel TONE
button, press and hold
STANDBY/ON for about
three seconds.
The display shows
RESET?
3 Press the front panel TONE– button.
The display shows
OK?
4 Within 5 seconds, press TONE+.
The display shows
OK
and the receiver should now be
reset
"Everyday room": Panasonic 58" Plasma, Dish HD DVR, Pioneer Elite vsx-23, BDP-23 BR, dv58avi universal dvd player, Paradigm Studio 20 V1, CC-450, Dayton HSU-10 subwoofer.
"Movie/Music room": Toshiba 65" DLP, Dish HD receiver, Marantz 7005, CC-4003, BD-7006, Polk LSI25's-LSi7's-LSiC, 2 original Dayton 10" "Mighty-Mites" subwoofers. (subject to change without notice).
Also have  MB Quart Vera VS05 +.....too much to list. Help me.
#3 of 6 OFFLINE   lemon-scented
lemon-scented
  • 1 posts
  • Real Name:gh
Posted September 15 2013 - 07:51 AM
Hello Edwin, I also have the VSX-56TXi that is having the exact same freezing issue. Were you able to get the issue resolved? What components did you replace or repair process did you use?
#4 of 6 OFFLINE   edwin108
edwin108
  • 6 posts
  • Real Name:Edwin
Posted September 15 2013 - 08:02 AM
I found several bad capacitors on the main control board and replaced them.  The capacitors I replaced are circled below:
Posted Image
I think the most important capacitor to replace is the disc-shaped one here:
Posted Image
#5 of 6 OFFLINE   edwin108
edwin108
  • 6 posts
  • Real Name:Edwin
Posted September 15 2013 - 08:08 AM
I should note that none of the capacitors that I replaced were bulging or leaking.  I tested them with a cheap tester from eBay like this one:
http://www.ebay.com/...=item3f231e19a8
Although this meter is not as precise as more expensive equipment, it can give you a good idea of which capacitors are way out of tolerance.
#6 of 6 OFFLINE   EarleD
EarleD
  • 732 posts
Posted September 25 2013 - 06:43 AM
This was my favorite/best receiver i ever owned.  great amps and awesome Pioneer sound.  If it had HDMI it would be a receiver to be reckoned with today
