Jump to content
Challenging room sub placement help
  • Please log in to reply
6 replies to this topic
#1 of 7 OFFLINE   JDErickson
JDErickson
  • 1 posts
  • Real Name:Jim
Posted April 24 2013 - 08:45 AM
[color=rgb(0,0,0);font-family:verdana, arial, helvetica, sans-serif;font-size:13px;background-color:rgb(230,237,245);]Please see diagram of my home theater room. Currently I have 1 sub at location listed. Is this a good spot for this room?[/color]
[color=rgb(0,0,0);font-family:verdana, arial, helvetica, sans-serif;font-size:13px;background-color:rgb(230,237,245);]I plan on adding a second sub. Where would be the best place to put it (and the first sub) in a 2 sub setup.[/color]
[color=rgb(0,0,0);font-family:verdana, arial, helvetica, sans-serif;font-size:13px;background-color:rgb(230,237,245);]SW-8MK2 [/color](current sub)
[color=rgb(0,0,0);font-family:verdana, arial, helvetica, sans-serif;font-size:13px;background-color:rgb(230,237,245);]specifications[/color]
[color=rgb(0,0,0);font-family:verdana, arial, helvetica, sans-serif;font-size:13px;background-color:rgb(230,237,245);]› Frequency Range....................................................38 Hz-150 Hz[/color]
[color=rgb(0,0,0);font-family:verdana, arial, helvetica, sans-serif;font-size:13px;background-color:rgb(230,237,245);]› Maximum Input Power.......................................................100 W[/color]
[color=rgb(0,0,0);font-family:verdana, arial, helvetica, sans-serif;font-size:13px;background-color:rgb(230,237,245);]› Driver Size.................................................................................8”[/color]
[color=rgb(0,0,0);font-family:verdana, arial, helvetica, sans-serif;font-size:13px;background-color:rgb(230,237,245);]› Dimensions (W x H x D) ...........12-3/16” x 14-3/16” x 12-3/16”[/color]
[color=rgb(0,0,0);font-family:verdana, arial, helvetica, sans-serif;font-size:13px;background-color:rgb(230,237,245);]› Weight (each)..............................................................20 lbs 4 oz[/color]
[color=rgb(0,0,0);font-family:verdana, arial, helvetica, sans-serif;font-size:13px;background-color:rgb(230,237,245);]› Power Consumption............................................................1.0 A[/color]
[color=rgb(0,0,0);font-family:verdana, arial, helvetica, sans-serif;font-size:13px;background-color:rgb(230,237,245);]› Power Requirement................................................120 V / 60 Hz[/color]
[color=rgb(0,0,0);font-family:verdana, arial, helvetica, sans-serif;font-size:13px;background-color:rgb(230,237,245);]› UPC........................................................................012562906133[/color]
[color=rgb(0,0,0);font-family:verdana, arial, helvetica, sans-serif;font-size:13px;background-color:rgb(230,237,245);]Andrew Jones Designed 100-Watt* Powered Subwoofer[/color]
[color=rgb(0,0,0);font-family:verdana, arial, helvetica, sans-serif;font-size:13px;background-color:rgb(230,237,245);]*50W FTC Power Output[/color]
[color=rgb(0,0,0);font-family:verdana, arial, helvetica, sans-serif;font-size:13px;background-color:rgb(230,237,245);]RW12D [/color](new sub arrives today)
[color=rgb(0,0,0);font-family:verdana, arial, helvetica, sans-serif;font-size:13px;background-color:rgb(230,237,245);]SPECIFICATIONS[/color]
[color=rgb(0,0,0);font-family:verdana, arial, helvetica, sans-serif;font-size:13px;background-color:rgb(230,237,245);]AMPLIFIER: BASH digital hybrid[/color]
[color=rgb(0,0,0);font-family:verdana, arial, helvetica, sans-serif;font-size:13px;background-color:rgb(230,237,245);]AMPLIFIER POWER: FTC Rated Power: 350 watts continuous @ <2% THD / Dynamic Power*: 825 watts[/color]
[color=rgb(0,0,0);font-family:verdana, arial, helvetica, sans-serif;font-size:13px;background-color:rgb(230,237,245);]DRIVE COMPONENTS: 12" (30.5cm) Cerametallic cone, front-firing woofer[/color]
[color=rgb(0,0,0);font-family:verdana, arial, helvetica, sans-serif;font-size:13px;background-color:rgb(230,237,245);]ENCLOSURE TYPE: Bass-reflex via front-firing CornerPort[/color]
[color=rgb(0,0,0);font-family:verdana, arial, helvetica, sans-serif;font-size:13px;background-color:rgb(230,237,245);]EXPORT VOLTAGE: 220 VAC 50/60Hz[/color]
[color=rgb(0,0,0);font-family:verdana, arial, helvetica, sans-serif;font-size:13px;background-color:rgb(230,237,245);]FEATURES: DCS control and feature set w/ 3 system presets[/color]
[color=rgb(0,0,0);font-family:verdana, arial, helvetica, sans-serif;font-size:13px;background-color:rgb(230,237,245);]FINISHES: Black Ash woodgrain vinyl[/color]
[color=rgb(0,0,0);font-family:verdana, arial, helvetica, sans-serif;font-size:13px;background-color:rgb(230,237,245);]FREQUENCY RESPONSE: 24-120Hz +/-3dB[/color]
[color=rgb(0,0,0);font-family:verdana, arial, helvetica, sans-serif;font-size:13px;background-color:rgb(230,237,245);]HEIGHT: 19.2" (48.8cm)[/color]
[color=rgb(0,0,0);font-family:verdana, arial, helvetica, sans-serif;font-size:13px;background-color:rgb(230,237,245);]INPUTS: L/R Line-level RCA jacks, L/R High-level speaker binding posts[/color]
[color=rgb(0,0,0);font-family:verdana, arial, helvetica, sans-serif;font-size:13px;background-color:rgb(230,237,245);]MAXIMUM ACOUSTIC OUTPUT: 116dB @ 30Hz 1/8 space, 1m[/color]
[color=rgb(0,0,0);font-family:verdana, arial, helvetica, sans-serif;font-size:13px;background-color:rgb(230,237,245);]OUTPUTS: None[/color]
[color=rgb(0,0,0);font-family:verdana, arial, helvetica, sans-serif;font-size:13px;background-color:rgb(230,237,245);]VOLTAGE: 110/120 VAC 60Hz[/color]
[color=rgb(0,0,0);font-family:verdana, arial, helvetica, sans-serif;font-size:13px;background-color:rgb(230,237,245);]WEIGHT: 49lbs (22.2kg)[/color]
[color=rgb(0,0,0);font-family:verdana, arial, helvetica, sans-serif;font-size:13px;background-color:rgb(230,237,245);]WIDTH: 14.6" (37.1cm)[/color]
[color=rgb(0,0,0);font-family:verdana, arial, helvetica, sans-serif;font-size:13px;background-color:rgb(230,237,245);]Thank you.[/color]
[color=rgb(0,0,0);font-family:verdana, arial, helvetica, sans-serif;font-size:13px;background-color:rgb(230,237,245);]Posted Image[/color]
#2 of 7 OFFLINE   schan1269
schan1269
    HTF Expert
  • 16,320 posts
  • Real Name:Sam
Posted April 24 2013 - 09:46 AM
The best place is trial and error. Nobody can tell you without being in the room.
#3 of 7 OFFLINE   fuzz092888
fuzz092888
  • 25 posts
  • Real Name:Alex
  • LocationNew New York
Posted April 25 2013 - 11:01 AM
There is this though.
http://www.audioholi...ment-guidelines
#4 of 7 OFFLINE   Tom Vodhanel
Tom Vodhanel
  • 2,215 posts
Posted April 27 2013 - 08:15 AM
 Try the top/left corner of the drawing.  Also, as you experiment with different sub positions be sure to recalibrate(and tweak the distance setting / phase setting each time you move the woof.
Tom V.
#5 of 7 OFFLINE   Doug Hess
Doug Hess
  • 68 posts
Posted April 28 2013 - 02:55 PM
Fuzz posted a link to an article that has the advice I always give. Rather than schlepping the sub around the room to try different spots, put it where you'll be sitting and YOU move around to find the best spot. This will identify the correct acoustical relationship between you and the sub. Works every time.
-Doug
#6 of 7 OFFLINE   Robert_J
Robert_J
    Lead Actor
  • 8,251 posts
  • Real Name:Robert
  • LocationMississippi
Posted April 28 2013 - 03:03 PM
-Doug
To do this 100% the correct way, you need to get your sub up to ear level.
#7 of 7 OFFLINE   schan1269
schan1269
    HTF Expert
  • 16,320 posts
  • Real Name:Sam
Posted April 28 2013 - 03:05 PM
Like Robert_J says...
Sub crawl(which is what you call it...and what I've occasionally offered up) is a bigger PITA than it sounds.
How many people here can put an SVS 13Ultra(either version) ear height?
You'd have more success buying one of these things...
http://www.amazon.co...pd_sim_sbs_hg_2
And rolling it around the room.
Edited by schan1269, April 28 2013 - 03:11 PM.
