Entry-level 4K 50" Ultra-HDTV available...price: $1,500! (1 Viewer)
lukejosephchung
San Francisco, CA., USA
Luke J. Chung
Found out about this yesterday at an Internet blog program called "HD Nation", hosted by Patrick Norton and ISF/THX-certified screen calibrator/home theater installer Robert Heron. It's an entry-level 50" 4K-resolution ultra-HDTV LED screen made by a company called Seiki. List price is $1,500, but it's listed at Amazon.com as taking pre-orders for $1,356!!! Opinions, anybody?? :biggrin:
Type A
Aurora Oregon
Ty
My first thought is the gimmicky "4k" from JVC and this 50" will be along the same lines. Will be interesting to hear Gregg Loewen's take on this one.
Steve Tannehill
R.I.P - 4.28.2015
Deceased Member
DFW
Steve Tannehill
I got a 73-inch 3D DLP set for less than that. I personally don't believe that 4K will show any benefit on a screen that small. Besides, there is no software.
lukejosephchung
Luke J. Chung
According to the technical specs on the Amazon page, it's able to upconvert to 4k...it would be interesting to see if there is a perceptible difference in image quality with currently-available HD sources using this feature...
uVSthem
uVSthem
Does anyone know what the refresh rate is for these 4K TVs? I see some of them listed as 120hz but are there true 120hz? Can they accept a 120hz signal
or do they just double a 60hz signal like 99% of the current 1080p TVs?
Jason Charlton
Baltimore, MD
Jason Charlton
Currently, it doesn't matter if the 4k display actually accepts a 120Hz signal because there is no video source that outputs at 120Hz.
Nothing outputs at higher than 60Hz, period.
Input signal and display refresh rate are totally separate things. 100% of current "120Hz" 1080p TVs double an incoming 60Hz signal to achieve 120Hz. Some "120Hz" 1080p TVs will accept a 24Hz signal (24fps from Blu-ray) and quintuple it to achieve 120Hz. That's it.
uVSthem
uVSthem
I was hoping to connect my PC which would beable to out put at 120Hz. I assume the TV would need a dual link DVI input for this or can 120Hz be sent over HDMI now?
Larsenv
