Contra Proferentem
- Apr 14, 2013
- Tom
The house I bought came with 5 speakers in the ceiling for the home theater room. This is obviously less than ideal for the front L/R and the Center channel. I have heard for the rears it is O.K.
I was wondering if I could install an in wall centre channel above the tv in the drywall, and then install in wall front L/R's into the cabinet doors on either side if the tv? I could router out the holes for the in walls into the cabinet face and secure the cabinet door. Would I need to build a box around the back of the speaker?
Any suggestions are greatly appreciated. My bigest factor is keeping the entertainment unit because they built it in, and I don't want to take the time or spend the money to rip it out ( I have replaced it with white doors so at least it is not red and black!). Also, it is a small room so I want to keep speakers off the floor (which is the main walkthrough in the basement).
Thanks!
http://imgur.com/lWz99un
Thanks!
