Jump to content
sound bars
  • Please log in to reply
2 replies to this topic
#1 of 3 OFFLINE   hilcntry
hilcntry
  • 3 posts
  • Real Name:Tom
Posted April 06 2013 - 08:26 AM
[font="tahoma, geneva, sans-serif;"]Greetings![/font]
[font="tahoma, geneva, sans-serif;"]Just found  this forum this morning. Need help selecting[/font]
[font="tahoma, geneva, sans-serif;"]a sound bar for bedroon tv. The man cave and living room[/font]
[font="tahoma, geneva, sans-serif;"]home theatres operating fine, wanted a better sound system[/font]
[font="tahoma, geneva, sans-serif;"]in the bedroon without going the whole theatre route.[/font]
[font="tahoma, geneva, sans-serif;"]Purchased a Yamaha ATS 1010 but couldn't get it to operate[/font]
[font="tahoma, geneva, sans-serif;"]with the Direct TV remote. What I don't need is another[/font]
[font="tahoma, geneva, sans-serif;"]dedicated (yamaha sound bar) remote. Have been able to[/font]
[font="tahoma, geneva, sans-serif;"]program all other equipment to function with the Direct Tv[/font]
[font="tahoma, geneva, sans-serif;"]remote. Is anyone using a sound bar and been able to[/font]
[font="tahoma, geneva, sans-serif;"]access it with Direct TV remote? [/font]
[font="tahoma, geneva, sans-serif;"]tia Tom hilcntry[/font]
#2 of 3 OFFLINE   schan1269
schan1269
    HTF Expert
  • 16,020 posts
  • Real Name:Sam
Posted April 06 2013 - 08:59 AM
Most "limited capability" soundbars don't come with a remote. The Boston TV series are programmed to work with the existing TV remote...and there are many others this way.
And lastly...did you try making the Soundbar work from the TV's remote...?
OR did you try from the "already works the TV's volume" Directv remote?
Little bit of a hint...has to be done from the TVs remote. You can't "program a soundbar" using the "learned" remote(be it Directv or Harmony...or anything else).
Your current soundbar will already work with your TV...if you program it with the TV remote.
Edited by schan1269, April 06 2013 - 08:59 AM.
#3 of 3 OFFLINE   hilcntry
hilcntry
  • 3 posts
  • Real Name:Tom
Posted April 06 2013 - 11:03 AM
To Schan
Thanks for the help. Should have thought of it myself' but back to plan A take it back
to Costco.
I had to use the tv remote to program the volume control and use the Direst tv remote to
program the on/off function. It worked for about 15 mins then went dead. Back to Costco.
Before I make purchases I usually check Amazon and read the reviews.
There were  a number of negative reviews that mentioned the unit going dead.
New to this forum, looks like knowledgeable people are ready to help.
Will be back.
