Jump to content
Samsung TV, Time Warner Cable Box and JVC DVD/Surround Sound Receiver
  • Please log in to reply
33 replies to this topic
#1 of 34 OFFLINE   kkarey27
kkarey27
    Extra
  • 18 posts
  • Real Name:Kathy
Posted April 01 2013 - 05:15 PM
Arghh... How many hours have I spent researching this?  I have a Samsung LN52B750.  I have a TWC cable box Explorer 8640 and JVC TH-G31.  The surround sound works with a DVD in the JVC receiver but I can't get the TV to use surround sound.  The cable box and JVC unit have separate HDMI cables to the tv.  I used a digital optical cable from the JVC unit to the TWC box.  How do I get the surround sound to play on the tv?  So frustrated..and out $50 on cables and wires.  Please help.  I'm ready to call the Geek Squad and that is so not me.
#2 of 34 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,715 posts
  • Real Name:Sam
Posted April 01 2013 - 06:55 PM
Have you turned on the DD in the cable box?
#3 of 34 OFFLINE   kkarey27
kkarey27
    Extra
  • 18 posts
  • Real Name:Kathy
Posted April 02 2013 - 11:14 AM
Color me stupid...I don't know what DD is.  How do I turn it on?
#4 of 34 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,715 posts
  • Real Name:Sam
Posted April 02 2013 - 11:19 AM
Dolby Digital.Your TV only handles PCM 2.0.If you've not set your cable box for audio/surround/DD...it isn't providing anything other than 2.0 to the receiver.
Edited by schan1269, April 02 2013 - 11:21 AM.
#5 of 34 OFFLINE   kkarey27
kkarey27
    Extra
  • 18 posts
  • Real Name:Kathy
Posted April 02 2013 - 11:21 AM
How do I set my cable box for Dolby?
#6 of 34 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,715 posts
  • Real Name:Sam
Posted April 02 2013 - 11:25 AM
Go into your settings. Every STB is different. I'm sure yours comes with a manual...or when you get into the audio setup, you should be able to find it.If this were a Directv box(which im familiar with), the process takes 10 seconds.
#7 of 34 OFFLINE   kkarey27
kkarey27
    Extra
  • 18 posts
  • Real Name:Kathy
Posted April 02 2013 - 12:57 PM
Just found the pdf for the Explorer 8640 manual.  There's a paragraph about changing the settings for Dolby.  Can't wait to get home and see if it works.  I'll let you know.
#8 of 34 OFFLINE   kkarey27
kkarey27
    Extra
  • 18 posts
  • Real Name:Kathy
Posted April 02 2013 - 01:54 PM
I changed the setting to Dolby and set the speaker to External but still no sound.  Is there a way to check if the optical cable is functioning? What now?
#9 of 34 OFFLINE   kkarey27
kkarey27
    Extra
  • 18 posts
  • Real Name:Kathy
Posted April 02 2013 - 02:05 PM
Got it!  The receiver had to be set on aux optical.  I hit the button and sound came through.  How cool.  Thank you so much!!
#10 of 34 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,715 posts
  • Real Name:Sam
Posted April 02 2013 - 02:11 PM
I misunderstood your original post. I assumed you "got sound", just not in "surround sound".
IT is possible TWC "kills" the "other outputs" when you use HDMI. So, try turning off the HDMI and using the component. The only thing you "lose" is 1080P VOD.
That "killing of the other inputs" is a point of consternation for numerous people...and why I call them Time Werner...and their alter ego...Concast.
#11 of 34 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,715 posts
  • Real Name:Sam
Posted April 02 2013 - 02:12 PM
Glad you sorted it...and the "kills the other outputs" isn't there...
#12 of 34 OFFLINE   kkarey27
kkarey27
    Extra
  • 18 posts
  • Real Name:Kathy
Posted April 02 2013 - 02:16 PM
Wait!  The sound is only coming from two speakers.  So then I accessed my Apple TV to play a movie and see if the sound worked.  The sound was a tv channel and the movie was playing on the screen.  I think we're on to something but it needs tweaking.  Any thoughts?  Also, once I got the sound through two of the speakers I turned the tv off and the sound of the channel was still coming through the speakers.  I'm holding 4 remotes in my hand.  Not cool.
#13 of 34 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,715 posts
  • Real Name:Sam
Posted April 02 2013 - 02:48 PM
Getting an "all-in-one" remote would be a good idea(look at the Woot Deals thread on here...if there are any left...worth it for a Samsung Tab, I almost bought one myself).
Anyway....
If you've turned on your DD and you are still only getting 2.0 it is possible...
1. Your cable box dumbs the signal back down to 2.0(of all "connections" the capablility of the "lowest common denominator" is what takes preference)
2. Your AVR can't accept 5.1(though this is doubtful since it is apparently taking it from a DVD player)
So...try DPL(Dolby ProLogic). I also just realised this is a DVD-HTiB(looked for it, previously on my phone).
It "should" accept 5.1 from your cable box...provided your cable box can send 5.1 from the optical while the HDMI is connected to a TV(see No. 1 above).
I have not seen a picture of the remote of the JVC...but it should have a "sound mode" button.
#14 of 34 OFFLINE   kkarey27
kkarey27
    Extra
  • 18 posts
  • Real Name:Kathy
Posted April 03 2013 - 04:42 AM
Here's a recap:  TV and AVR connected with HDMI. TV set to Dolby.  TV and Cable Box connected with HDMI and Cable Box set to Aux Opt.  Cable box and AVR connected with Optical cable.  And lastly, Apple TV connected to TV with HDMI.  Movies on DVD player have surround sound.  Some TV channels (cooking) have sound from all 5 speakers but some channels have sound only coming from 1 or 2 speakers. I'm good with that. I think it's just a channel thing.
How do I access my Apple TV and watch my Itunes movies with surround sound?  The Apple TV is connected directly to TV with HDMI and not connected to anything else.   We're almost there.  When I access my Itunes movies on Apple TV the sound from the speakers is the channel I had on the TV before accessing the Apple TV.  So my movie is playing and the sound is from a TV show. Thanks for all your help.  I was ready to trash everything and just listen to the TV speaker.
#15 of 34 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,715 posts
  • Real Name:Sam
Posted April 03 2013 - 05:55 AM
You can't connect anything directly to the TV, and then audio from it to the JVC. The JVC, being limited capability HTiB, doesn't have enough inputs.
HTiB does not equal AVR.
Which generation of ATV do you have? They are different. Some have HDMI only, some have HDMI and a toslink. Some have HDMI, toslink and analog audio. So, which one you got?
IF your ATV has a toslink, you'll need a toslink switch.
http://www.amazon.co...=toslink switch
That is the fact of life of buying limited capability HTiB.
If your ATV does not have a toslink, and only the HDMI...
If your TV has an optical(or digital coax) output, you can run that to a toslink switch. (digital coax will require a dig coax -> optical adapter)
#16 of 34 OFFLINE   kkarey27
kkarey27
    Extra
  • 18 posts
  • Real Name:Kathy
Posted April 03 2013 - 06:26 AM
OK, so I'm confused again, but trying desperately to figure out the terminology.  My Samsung LN52B750 has a digital audio out optical.  My TV has 4 HDMI ports.  Should i connect the digital audio optical cable from my tv to the Cable box or to the HTiB?  There is a single digital audio optical plug on both the cable box and the HTiB box.  How do I know if I have toslink?
#17 of 34 OFFLINE   kkarey27
kkarey27
    Extra
  • 18 posts
  • Real Name:Kathy
Posted April 03 2013 - 06:27 AM
I have one optical cable and it goes from the cable box to the HTiB box.
#18 of 34 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,715 posts
  • Real Name:Sam
Posted April 03 2013 - 06:41 AM
It would help to post a picture of the rear of this G31. I've only found the G30 through searches. I doubt there are (m)any differences between them.
You have...
ATV(which one?)
Cable STB(connections on cable/sat STB have been pretty much universal for 15 years now...except in implementation)
LCD that(luckily) has a digital toslink.
HTiB.
Your HTiB has....1 optical input.
You have two sources(being the ATV and STB) that need "some connection" to the HTiB.
So...covering all the bases(cause I have no idea which ATV you have...)
If your ATV has a toslink...you need...
A toslink switch to switch between the audio from the ATV and STB.
If your ATV does not have a toslink...you need...
A toslink switch to switch between the STB and the TV(cause the audio will have to go there first).
Regardless...you need the toslink switch.
You "could" spend $50+ on a HDMI switch that has a 5.1 capable toslink(but...getting back to the "issue there" is you have to make sure the toslink is capable of 5.1 when the HDMI is connected to a TV...as some HDMI switches dumb the signal down to 2.0...because of the TV...separating the toslink from the HDMI at the source, and again, source being the STB/ATV, you mitigate the 5.1 dumbing down to 2.0 problem)
#19 of 34 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,715 posts
  • Real Name:Sam
Posted April 03 2013 - 06:55 AM
By the way(since I was using phone yesterday and JVC/USA was wonky)...
The G31 has two analog audio inputs. 1/8th on the front and a standard red/white on the back. If your ATV has an analog audio out, you can connect it.
I don't use an ATV so I have no idea how much content can be streamed other than 2.0 on it. I use a laptop.
If there is very little 5.1 over the ATV, and you have the analog, there is no reason not to use it and use the JVC's onboard DPL.
#20 of 34 OFFLINE   kkarey27
kkarey27
    Extra
  • 18 posts
  • Real Name:Kathy
Posted April 03 2013 - 07:12 AM
Real quick:  can you help me with some of the acronyms?  ATV (apple tv)? STB?  I'm still confused.  I have a Samsung TV LN52B750(researched everything before I bought this).  I have a cable box from Time Warner Cable Explorer 8640 and the HTiB JVC TH-G31(this was a gift - not my choice).  I also connected my little black box Apple TV to my Samsung TV. My apple tv is only 1.5 years old.  Does that help?
http://resources.jvc...00/01/17/14.PDF
