Jump to content
Need Help With Epson 705HD - Flashing Lights
  • Please log in to reply
5 replies to this topic
#1 of 6 OFFLINE   jwh92020
jwh92020
    Extra
  • 15 posts
Posted April 01 2013 - 02:48 PM
I just received an Epson 705HD projector that I purchased on Ebay. Prior to purchasing it, I spoke with the seller who told me it would light up, but because everything displayed was upside down, he didn't know how to check lamp hours. I paid $150 for it and figured on putting in an aftermarket lamp (under $100) as this would be my outdoor projector. When I turn on the projector, it shows the Epson logo, goes blue screen, then the lamp light begins flashing red and the fan starts to roar. This was never mentioned to me or I would have passed on the unit. According to the manual,  it could be the lamp or it could be something else inside the projector. I hate the thought of dropping $70 minimum on a lamp, only to find out it's something worse. At that point, the projector becomes a door stop. Anyone have an idea of some other troubleshooting I can do?
#2 of 6 OFFLINE   FoxyMulder
FoxyMulder
    映画ファン
  • 5,027 posts
  • Real Name:Malcolm
  • LocationScotland
Posted April 01 2013 - 03:24 PM
If the manual specifically says the red light flashing is a warning to change the bulb then change it, on my projector you get the same warning lights and it just means the bulb has reached the recommended hours and needs changed, maybe its also the air filter clogged up with dust.
I did a Google and all i could find was this info on service menus and Epsons, use at your own risk, also be aware that sometimes the bulb hours can be reset if the user knows how, the secret service menu should give you that info if it has been changed.
Epson Service Menu
Epson Projector Service Menu Access Method 1
  1. Press the {MENU} button for at least 5 seconds.
  2. Then press the {ESC}, {ESC}, {TELE} & {WIDE} buttons within 4 seconds.
  3. The After Service (AS) Menu will be displayed.
  4. To exit, turn the power off.
Epson Projector Service Menu Access Method 2
  1. Press the {ENTER} & {MENU} buttons at the same time for at least 5 seconds.
  2. To exit, turn the power off.
Epson Projector Service Menu Access Method 3
  1. Using the remote control: Turn the power on.
  2. Set the "Brightness" to max.
  3. Then press and hold the {HELP} button for at least 5 - 7 seconds until the Service Menu is displayed.
     :Fun Movie Quotes:
"A good body with a dull brain is as cheap as life itself"
"Maybe it's a sheep dog... let's keep going"
"Please doctor, I've got to ask this. It sounds like, well, just as though you're describing some form of super carrot"
#3 of 6 OFFLINE   jwh92020
jwh92020
    Extra
  • 15 posts
Posted April 01 2013 - 03:32 PM
The manual says the flashing light is the bulb or something inside the projector. It does not stay on long enough to get into any menu. Thanks for the input. I may have to put in a bulb and see what happens. I found a non Epson replacement for $60. Worst case is I sell an "almost new" bulb to recover some $ I spend on it. As for the projector, there is a place in Phoenix that will bench test it for me, Minimum charge - $100. Guess I'll try the bulb and cut my losses.
#4 of 6 OFFLINE   FoxyMulder
FoxyMulder
    映画ファン
  • 5,027 posts
  • Real Name:Malcolm
  • LocationScotland
Posted April 02 2013 - 07:34 AM
At that price i'd buy the bulb, the ones for my projector cost between $350 and $400, i think the seller has been a little untruthful with you but if a new bulb works then all will be good, if it has air/dust filters for collecting dust then try and purchase a new one of those too.
Edited by FoxyMulder, April 02 2013 - 07:35 AM.
  • Gregg Loewen likes this
     :Fun Movie Quotes:
#5 of 6 OFFLINE   jwh92020
jwh92020
    Extra
  • 15 posts
Posted April 02 2013 - 09:36 AM
I ordered a non Epson bulb from Amazon yesterday - $65 w/local express delivery. It should be here this afternoon. Like you said, if it works, all will be good. I took out the filter and it is clean, but I blew it out w/an air spray can just to be sure. If the projector works with this bulb, I'll order an OEM bulb and save this for a back up. I've had pretty good experience w/non OEM bulbs but in this case I'd rather have an Epson bulb for regular use. As for Ebay, it all comes down to "you pay your money and you take your chances". Thanks again for your input. I'll post the results after I get the bulb installed.
#6 of 6 OFFLINE   jwh92020
jwh92020
    Extra
  • 15 posts
Posted April 02 2013 - 04:35 PM
Installed the bulb, projector seems to be working. The flashing lights are gone, but the "Auto Iris" feature had to be disabled. It was continually clicking off and on. The manual said that this happening would also cause the same flashing lights as a dead bulb. I'm going to use this for a few outdoor showings and if all stays well, I'll buy an OEM lamp. Foxy Mulder - thanks again.
Edited by jwh92020, April 02 2013 - 10:50 PM.
