Jump to content
FIRST TIME LOGGING IN HERE? YOU WILL NEED TO RESET YOUR PASSWORD
PLEASE NOTE: If this is your first time logging in since we moved, you will need to reset your password. Please use the I've forgotten my password link here or on the sign In screen. If your email address has changed since you signed up or you don't get the password reset email after 10 minutes of requesting, please send an email to support @ hometheaterforum.com.
If you are a guest, welcome and consider creating a free account. Its that much easier to stay on top of everything at the site and be eligible for our contests and giveaways.
Network Nightmare, smart tv, av receiver, bluray etc
  • Please log in to reply
3 replies to this topic
#1 of 4 djpleasure
djpleasure
    Newbie
  • Pip
  • 2 posts
Posted March 11 2013 - 02:01 PM
Hi, hopefully someone may have the answer for this: I have the following: LG Smart TV Toshiba Bluray Pioneer AV Receiver Xbox 360 Western Digital Live Hub All of which have Ethernet for network. I do not want to run 5 separate cables from my router to the AV stand in which they are situated. I purchased multiple cat 6 cables as well as an 8 port gigabit switch, thinking this may help. Tested, all connected but only the TV and the av receiver on, connected to LG 3D demo, connection keeps dropping, connect direct and omit the switch, works fine, thinking that it is due to the av receiver being network enabled at the same time as the TV, even though the receiver should only require access if using internet radio. How do I get around this? to buy wireless dongles for each device is not economical, to run separate Ethernet cables is just cable overkill, any help appreciated
#2 of 4 Steve Tannehill
Steve Tannehill
    Advanced Member
  • 4,687 posts
Posted March 11 2013 - 02:10 PM
Hi, Nick, welcome to HTF! One Ethernet run to the switch, then runs to the devices from the switch should work.
#3 of 4 djpleasure
djpleasure
    Newbie
  • Pip
  • 2 posts
Posted March 11 2013 - 02:15 PM
hi, internet on tv keeps cutting out if i do that, like it is switching, no issues with my main internet connection or router, virgin 100mbit superhub
#4 of 4 liaisonleigh
liaisonleigh
    Newbie
  • Pip
  • 7 posts
  • Real Name:Leigh
Posted April 03 2013 - 06:46 AM
I am thinking maybe your issue is IP address related... perhaps limited on the modem/router end, if I'm wrong ok, happy to explain if I'm right... Having said that, interesting situation though...
