Jump to content
Yamaha RX-V363 SUBWOOFER SUGGESTIONS
  • Please log in to reply
3 replies to this topic
#1 of 4 OFFLINE   CALCULUS2UK
CALCULUS2UK
  • 14 posts
Posted March 08 2013 - 11:04 PM
Hello Folks I have a Yamaha RX-V363 Receiver and I already have some speakers and have been trying to get a sub woofer to power it. My budget is about 80euros. Counting on you guys Thx
#2 of 4 OFFLINE   Al.Anderson
Al.Anderson
  • 2,234 posts
  • Real Name:Al
Posted March 09 2013 - 02:02 AM
How big is your room You're really not going to get a lot for 80 euros, definitely no bigger than an 8 inch driver. If your room is bigger than 4x4 meters you might want to hold off and try and double the budget.
#3 of 4 OFFLINE   CALCULUS2UK
CALCULUS2UK
  • 14 posts
Posted March 10 2013 - 09:01 PM
Hi Thx for the info. My room is about 15m2 and can you make any suggestions as to the sub woofer so I can check out the prices and work towards it. thx
#4 of 4 OFFLINE   Al.Anderson
Al.Anderson
  • 2,234 posts
  • Real Name:Al
Posted March 11 2013 - 02:24 AM
I don't know the European distribution channel at all. In the US, BIC makes a good 2nd-tier sub, and is often recommended in your situation; so something like this: http://www.amazon.co...words=subwoofer The closest I could find on Amazon.uk is this (and this is a 10", not a 12" driver): http://www.amazon.co...3010968&sr=1-32
