Jump to content
Problem connecting DVD to LED Flat panel
  • Please log in to reply
5 replies to this topic
#1 of 6 OFFLINE   LilBro
LilBro
  • 14 posts
Posted March 02 2013 - 01:40 PM
My daughter & her fiance gave us their Westinghouse LD4655VX television. I connected our Panasonic DVDCV51 player to it using the RGB video9 & optical audio connection. Unfortunately, when I play a disc, I get serious buzz on the audio the the video is B/W only. Where would my connections be mucked up? Or is the Panny dying? Thank you.
#2 of 6 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,787 posts
  • Real Name:Sam
Posted March 02 2013 - 01:52 PM
My first guess(cause I haven't looked at either one yet)... The Component input on the TV only works when the audio is connected correctly... That TV, I assure you, does not have an optical input. You need to connect the analog red/white with the component. I will be looking at the DVD player regardless.
#3 of 6 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,787 posts
  • Real Name:Sam
Posted March 02 2013 - 01:55 PM
I will also fathom a guess that the TV may not digest RGB, so you might have to switch the DVD player to YCrBr(or the other way).
#4 of 6 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,787 posts
  • Real Name:Sam
Posted March 02 2013 - 02:01 PM
Now I know the problem... That TV does not use the RGB(which I assume you meant the component, red/green/blue) connector...cause it doesn't have one. The only thing you can use is a standard composite cable... http://www.amazon.co...composite cable Considering how cheap an upconverting 1080P DVD player is...I'd get one... http://www.amazon.co...words=1080p dvd
#5 of 6 OFFLINE   LilBro
LilBro
  • 14 posts
Posted March 05 2013 - 09:52 AM
I misnamed the connection. I used high quality composite cables. Today I double checked the connections to make sure the Pr/Pb/Y cables on the DVD were connected to the correct posts on the TV. No go. The picture is B/W whether a disc is in or I just use the Panny's menu. The sound is thru the optical out to my 5.1 receiver. Beaucoup 60Hz hum on the TV.
#6 of 6 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,787 posts
  • Real Name:Sam
Posted March 05 2013 - 12:09 PM
That tv doesn't have a PrPbY connection.
