Jump to content
Icon Remote IR34A programing for receiver?
  • Please log in to reply
1 reply to this topic
#1 of 2 OFFLINE   dave1987
dave1987
  • 7 posts
Posted February 28 2013 - 03:03 PM
I'm trying to get my Icon Remote IR34A to work with my Yamaha R-v1103 A/V Receiver using the codes for Yamaha audio devices (the ones in the remote). I have been able to get two codes to "work" but neither of them will turn the unit ON. If I have it on already, most everything works fine, but if I power it off (which the remote WILL do), I cannot turn it back on using the remote, only the power button. I don't have an original remote for the unit and don't want to ebay for one unless absolutely necessary. I know that the remote will accept codes from another remote and I can program those codes to the corresponding buttons, so if I have to find the original remote, I suppose I could. Anyone else ever have this issue with powering your receiver on with the remote, and it not working?
#2 of 2 OFFLINE   dave1987
dave1987
  • 7 posts
Posted March 07 2013 - 02:26 PM
Figured it out! Ordered a remote on ebay, cheap, and programmed the icon remote. The original remote has power on and standby, the same button is not used to turning the receiver on an off.
