maxsound7
Grip
- Dec 31, 2012
- mike
I would like to build simple but good boxes for the speakers below, have a shop and the tools just need some knowledge and advice. Please let me know what size and interior clear cu.ft would be ideal. Also, if any fibre fill/insulation, interior bracing, sizing and material (ie. 3/4" mdf) etc. should be used. If you have any reference pics or links to similar builds that would be very helpful as well. Image Dynamics 6.5" CXS 64 component set. I will be mounting the tweeters at the center of the mid as recommended by the manufacturer in the product document. How do I handle crossovers? these were car audio speakers so do I just install the same crossovers provided or can my NAD t775HD handle crossovers? I dont know much about crossovers or how to build new ones. Specifications as follows: Speaker Size 6-1/2" Design 2-way Component System Tweeter Design Dome Tweeter Composition Silk Woofer Composition Carbon Fiber Woofer Surround Nitrile Butadiene Rubber (NBR) Peak Power Handling 250 watts RMS Power Handling 125 watts Sensitivity 90 dB Frequency Response 55 - 25,000 Hz Impedance (Per Voice Coil) 4 ohms Shallow Mount Installation No Top-Mount Depth 3" Bottom-Mount Depth 3-1/8" Cutout Dimensions 5-5/8" x 5-5/8" The total system will be 2.1: My receiver/amplifier is a NAD t775HD. The subwoofer box I am building is here near the end of this thread:http://www.hometheaterforum.com/t/326415/help-with-final-speaker-selection#post_4029506 its 50% complete. [ATTACHMENT=474]CXS64V2 TS.pdf (17k. pdf file)[/ATTACHMENT] [ATTACHMENT=475]ID1.png (25k. png file)[/ATTACHMENT]
