Jump to content
Need Help on Co-ax cable and Optical cable.
  • Please log in to reply
2 replies to this topic
#1 of 3 OFFLINE   pgpravin
pgpravin
  • 2 posts
Posted February 17 2013 - 07:46 PM
Hi all, I am proud owner of Yamaha YHT 196 from Mumbai Maharashtra. I got my system delivered and installed. But when it came for an connectivity I had to choose for a better co-as cable and Optical cable. when i dialed some numbers and searched on net I fall down with the options and range available in the market with all different price tags. Can anybody help me in specifications needed with price tag. I will be grateful.
#2 of 3 OFFLINE   gartronics
gartronics
  • 101 posts
Posted February 22 2013 - 07:10 PM
If your equipment supports optical, by all means that is the better option. You can probably get a good deal on optical audio cable at monoprice.com .
#3 of 3 OFFLINE   Al.Anderson
Al.Anderson
  • 2,385 posts
  • Real Name:Al
Posted February 22 2013 - 09:27 PM
I don't follow what you're asking, but if your components handle both optical and digital coax, the coax is usually cheaper. There is absolutely no difference in sound quality between digital coax and optical. Monoprice.com usually has the best prices.
