Jump to content
Advice for Speaker selector switch
  • Please log in to reply
2 replies to this topic
#1 of 3 OFFLINE   Mzenji
Mzenji
  • 2 posts
Posted February 06 2013 - 08:43 AM
I have a HK AVR 144 (max power is 80W) receiver and 2 pairs of Yamaha outdoor (6 ohm) speaker. Looking for advice on what selector switch to purchase that can work with my receiver without frying it. I want to be able to play music in 2 different zones (2 pais of speakers).Thanks for your advice.
#2 of 3 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,678 posts
  • Real Name:Sam
Posted February 06 2013 - 09:08 AM
Most speaker switches are going to present a "half-load" of your speakers...so they won't help, unless you bought one meant for 4 pairs, or more, with "impedance matching"(I've never seen a 2 pair switch with impedance matching). However, my advice is to run the pairs in series...which will double the ohm load... So, you take both rights and run positive to one speaker...its negative to the other positive...negative back to the amp. Repeat with the lefts. If it sounds daunting to run the speaker wire that way, there are ways to T the wire where you don't use as much as you'd think.
#3 of 3 OFFLINE   Mzenji
Mzenji
  • 2 posts
Posted February 06 2013 - 03:58 PM
