Jump to content
Surround sound question
  • Please log in to reply
10 replies to this topic
#1 of 11 OFFLINE   Big Rick
Big Rick
  • 3 posts
Posted February 04 2013 - 04:06 AM
Recently i got a Logitech Z506 surround sound system for my gaming PC (vast improvement over my old TV speakers) but its using the 3.5mm jack that plugs into the headphone socket in the back of my TV. I am currently looking at getting a sound card for my computer but i was wondering which input/output system is the best quality, although its nod bad at the moment it isnt what i would call great The options on the back of my Sub for the sound system are; - 3.5mm 'audio in' (think mic in type) - 6 Ch - Stereo L/R Just want to know so i get the right sound card first time and apologies if this has been asked before
#2 of 11 OFFLINE   Al.Anderson
Al.Anderson
  • 2,344 posts
  • Real Name:Al
Posted February 04 2013 - 05:32 AM
Are you asking which sound card ot get, or what inputs to use on the Z506? Assuming the former, of the 3 input options, only '6 ch' gives you surround sound; the rest are stereo/simulated surround sound. So defintitely 6 channel. You will need a sound card for that, it's not meant to take input from standard steeo equipment (like a TV or receiver). So if you're building a HT-PC, great; otherwise you'd be better off getting a receiver and routing everything into that.
#3 of 11 OFFLINE   Big Rick
Big Rick
  • 3 posts
Posted February 04 2013 - 06:41 AM
Yeah, i was wondering which inputs to use, meaining i can thus get the right sound card
#4 of 11 OFFLINE   schan1269
schan1269
    HTF Expert
  • 16,037 posts
  • Real Name:Sam
Posted February 04 2013 - 08:02 AM
Do they still make 3 plug/6 channel soundcards? I thought mini toslink killed that off 10 years ago and HDMI killed off mini-toslink 3 years ago...
#5 of 11 OFFLINE   schan1269
schan1269
    HTF Expert
  • 16,037 posts
  • Real Name:Sam
Posted February 04 2013 - 08:45 AM
I did find this... http://www.amazon.co...nalog soundcard Seems most 5.1 or 7.1 analog sound cards are $100+. HDMI cards aren't much more.
#6 of 11 OFFLINE   Big Rick
Big Rick
  • 3 posts
Posted February 04 2013 - 11:01 PM
I'm pretty sure that this card has the right outputs (6 channel) for what im after, but if anyone knows for sure can you let me know please http://www.novatech....55-1uan00z.html Cheers in advance edit - i am limited in choice somewhat as the only accessible ports on my motherboard are PCI-express not PCI (the PCI slot is obstructed by my housebrick of a graphics card)
#7 of 11 OFFLINE   chapcantfixistv
chapcantfixistv
  • 3 posts
Posted February 06 2013 - 02:41 AM
Hi, I have a pioneer tv model PDP4270XD also Pioneer surround system. It's from about 2007 . I am trying to get my sky hd to play in surround sound! I have got sound but just stereo. I have loads of cables 2 x hdmi 2 x scary 1 x digital optical cable I just like some help to get the best performance out of my system. Regards, rob
#8 of 11 OFFLINE   schan1269
schan1269
    HTF Expert
  • 16,037 posts
  • Real Name:Sam
Posted February 06 2013 - 02:57 AM
You need to connect the Sky STB directly to your AVR...(your TV is dumbing it down to 2.0PCM)
#9 of 11 OFFLINE   chapcantfixistv
chapcantfixistv
  • 3 posts
Posted February 11 2013 - 05:12 PM
Hi, Thanks for the reply, but could you explain as I am not massively technical wise , sky stb? Avr? Also what would be the best cables to use? Regards.
#10 of 11 OFFLINE   schan1269
schan1269
    HTF Expert
  • 16,037 posts
  • Real Name:Sam
Posted February 11 2013 - 05:44 PM
Set Top Box Audio Video Receiver Your Sky HD(in other words...the STB) needs to have audio directly connected to the AVR(see above).
#11 of 11 OFFLINE   chapcantfixistv
chapcantfixistv
  • 3 posts
Posted February 12 2013 - 04:35 AM
Thank you! i'll give it a go
