Jump to content
Subwoofer suggestion - upgrade from Def Tech ProCinema 600 setup
  • Please log in to reply
3 replies to this topic
#1 of 4 OFFLINE   db4809
db4809
  • 2 posts
Posted February 04 2013 - 03:54 AM
Just got my first home theater set up....I purchased a Def Tech Pro Cinema 600 it came with the Denon 2113 as a package deal at best buy. The sound is good, but I am already looking to improve.... I swapped out the center channel for a Def Tech Pro Cinema Center 1000... and am now looking to upgrade my subwoofer as well.... any suggestions on what a good step up from the Pro Cinema 600 sub would be.... here are the specs on it... 250-Watt powered subwoofer with two 8” cones Range: 22Hz- 150Hz My budget is $500 but if there is something that is just exponentially better at $700 then I might stretch to get there.... Room is 15x20x9 Thanks for your help....
#2 of 4 OFFLINE   Dave Upton
Dave Upton
  • 2,054 posts
  • Real Name:Dave Upton
  • LocationHouston, TX
Posted February 04 2013 - 04:09 AM
If you're willing to stretch the budget, you can't go wrong with this sub or its vented twin at $799 shipped: http://www.powersoun...m/products/xs15 http://www.powersoun...m/products/xv15
#3 of 4 OFFLINE   db4809
db4809
  • 2 posts
Posted February 04 2013 - 09:30 AM
Thanks, I will check them out
#4 of 4 OFFLINE   Lauren Upton
Lauren Upton
    HTF Game Reviewer
  • 19 posts
Posted April 11 2013 - 05:22 AM
Appreciate the advice!
