Jump to content
my tv will not stay on!!!! grrr
  • Please log in to reply
1 reply to this topic
#1 of 2 OFFLINE   shaybear1578
  • 1 posts
Posted January 24 2013 - 10:13 AM
i have a mitsubishi 60 in it will not stay on,some days its fine some days its bad. it turns off a amber light blinks some times for 2 or 3m and sometimes for over a hour. when it stops blinking i turn on the tv,sometimes its works fine but most of the time the screen will not turn on but the sound is on then the tv will turn blue the turn off right away. i have unplugged it.moved it dusted but nothing works! what should i do?:confused:
#2 of 2 OFFLINE   schan1269
    HTF Expert
  • 16,503 posts
  • Real Name:Sam
Posted January 24 2013 - 10:46 AM
Sounds like either... 1. The power supply is taking a dump. (not cheap) 2. One of the caps that relays power off the supply is in the early stages of blowing. (not cheap either...but cheaper than a power supply) It is fixable provided you don't wait till the PS completely dies...or if it is a cap...till the cap finally does pop and takes everything "else it is associated with" out.
