Jump to content
No Color Using Component Cable Connections?
  • Please log in to reply
4 replies to this topic
#1 of 5 OFFLINE   AllanP
AllanP
    Extra
  • 23 posts
Posted December 29 2012 - 02:42 PM
I just updated my "older" system by replacing the "S" video connections with new "component" connections, going from my Pioneer DVL-919 to the Marantz SR-18 and out to a 51" Samsung Plasma TV. Sound, clarity, etc. is all good but NO COLOR, just B&W! Can anyone advise what the problem may be? I am not an expert by any means so all help will be appreciated. Thanks in advance!
Of course, that's only MY opinion, I could be wrong!
#2 of 5 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,612 posts
  • Real Name:Sam
Posted December 29 2012 - 03:23 PM
Have you changed it from RGB to YCrBr? It might be the other way... But...Component can carry both...but your display doesn't necessarily understand both...
#3 of 5 OFFLINE   SonicSC
SonicSC
    Extra
  • 15 posts
Posted December 29 2012 - 03:33 PM
It's easy to get those RCA cables plugged into the wrong spots. To start, make sure you've got the 3 video component cables (green, blue and red) going into the matching jacks, and nothing into the yellow composite jack. Then make sure you've selected the correct input - component - on your TV. I know that seems basic, but if that's all correct, let me know, and I'll see if I can't help further.
#4 of 5 OFFLINE   SonicSC
SonicSC
    Extra
  • 15 posts
Posted December 29 2012 - 03:34 PM
Sorry, I didn't see your reply before I posted mine. Sounds like we're both thinking the same thing.
#5 of 5 OFFLINE   AllanP
AllanP
    Extra
  • 23 posts
Posted December 30 2012 - 12:36 PM
Hello all! Thanks for your replies. I did something I should have done 'initially' - I located the instruction manual for the DVL-919 and after "searching" I found out how to access the confusing "menu" to switch the output from "S" video to "component!" For sure, given current systems, this is not exactly a user friendly device and the instructions . . . well, you know! Anyway, I have color now. . . hooray! Now all I have to do is convert my Beta & VHS tapes to DVD and I'll be all set! :P
