Jump to content
THIN SIDE FIRING SUBWOOFER RECOMMENDATIONS
  • Please log in to reply
8 replies to this topic
#1 of 9 OFFLINE   coramdeo
coramdeo
  • 4 posts
Posted December 22 2012 - 05:37 PM
I have a mix-match home theater system for our small family room and am looking for a "thin" powered subwoofer to fit behind our entertainment center. I have an Onkyo TX-SR309 receiver with 65w-85w/per channel. I've been looking at the Yamaha NS-SW210 (6.5" wide). The specs sound good, but the $200+ price tag is somewhat high for my budget. I would appreciate any suggestions!! [/SIZE][/SIZE]
#2 of 9 OFFLINE   Jason Charlton
Jason Charlton
    Producer
  • 3,106 posts
  • Real Name:Jason Charlton
  • LocationBaltimore, MD
Posted December 24 2012 - 08:28 AM
There aren't a whole lot of options when it comes to those requirements.
Essentially, subwoofers are meant to "move air".  Their ability to move lots of air is governed by two factors: 1) the area of the driver surface (so a larger woofer - 12" or more - is a necessity), and 2) the excursion, or travel, of the woofer (in and out) as it produces sound.
Hence, 99% of subwoofers are in big boxes.
With a small, thin enclosure, you're dramatically limiting both of these factors, so don't expect much in terms of performance.
That being said, I did a quick search on Amazon and found this option.  Less than 5" deep, so it fits your geometry requirements.  I have no firsthand experience with this, but the reviews seem mostly positive.
Are you new to the Home Theater Forum? Stop by the New Member Introductions area and introduce yourself! See you there!
#3 of 9 OFFLINE   coramdeo
coramdeo
  • 4 posts
Posted December 24 2012 - 02:12 PM
Thanks for your reply Jason. In your opinion, would the Yamaha Sw210's quality justify the $90 difference in price?
#4 of 9 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,632 posts
  • Real Name:Sam
Posted December 24 2012 - 02:17 PM
Here is the best "flat" sub...and I never recommend it. http://www.amazon.co...kef t subwoofer
#5 of 9 OFFLINE   Jason Charlton
Jason Charlton
    Producer
  • 3,106 posts
Posted December 24 2012 - 04:16 PM
Hard to say for certain. The Yamaha is smaller, but "claims" to reach 30Hz, while the other is a larger driver and has more power (subs are the only speaker where power actually matters). It's also sort of a no-name brand... If I had to pick one, I'd probably take a chance with the one from Amazon, just because it's cheaper and I don't think a 50% price jump is going to be worth 5 Hz. With subs you want size, power, and low end. The Amazon sub has the edge in 2 out of 3...
#6 of 9 OFFLINE   Robert_J
Robert_J
    Lead Actor
  • 8,205 posts
  • Real Name:Robert
  • LocationMississippi
Posted December 25 2012 - 09:15 AM
Not really. The only true thing to say about subs (or the bass portion of any speaker) is stated in Hoffman's Iron Law - http://www.salksound.com/wp/?p=56
For an odd sized sub like this, I'd go DIY. You have 6.5" of depth but what are your other limitations on size (height and width)?
#7 of 9 OFFLINE   coramdeo
coramdeo
  • 4 posts
Posted December 25 2012 - 11:03 AM
I don't mean to impose on your time, but I have a couple of additional questions. What are your thoughts about the Yamaha YST-SW80 and would I need to provide space between the subwoofer and the wall. It would be a perfect fit between the wall and my entertainment center. P.S. Merry Christmas . . .
#8 of 9 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,632 posts
  • Real Name:Sam
Posted December 25 2012 - 11:39 AM
Where are you finding a SW80? That thing didn't get love when it was new, a decade ago.
#9 of 9 OFFLINE   coramdeo
coramdeo
  • 4 posts
Posted December 25 2012 - 12:58 PM
Enough said!! I get the message. I found the SW80 on ebay. The frequency range 23-170HZ sounded great, but I'll take your hint and stay with the amazon product. Thanks again.
