Jump to content
Xbox360 to Surround Sound - HDMI - Component Converter? Need Help
  • Please log in to reply
6 replies to this topic
#1 of 7 OFFLINE   ceemrice
ceemrice
  • 4 posts
Posted December 13 2012 - 06:20 AM
Hi, I have a little complicated question, so I hope I am wording it correctly. :confused: I have a Samsung SmartTV hung up on my wall, with a single HDMI wire running through the wall into a Denon AVR-1913 receiver. Enter Problem: old Xbox360 without HDMI capability. Is there some kind of HDMI-component cable converter that will work with my surround sound system (at a decent price) ? I’ve seen some for around ~$40 with the 5 slots for YPBPR and Red/White stereo audio cables, but I am not sure if they are capable to produce sound/audio via that setup. I appreciate the help! –Chris
#2 of 7 OFFLINE   Jason Charlton
Jason Charlton
    Producer
  • 3,103 posts
  • Real Name:Jason Charlton
  • LocationBaltimore, MD
Posted December 13 2012 - 06:34 AM
Just to clarify - the signal is going from the XBox (component video) to the reciever (HDMI) so you need a "component to HDMI converter", not the other way around.  That's important to note because you can't go the other way.  You can't "downconvert" HDMI (digital) to component (analog).   I edited the rest of my response because I was an idiot.   Audio isn't even a factor here - since the component video output from the XBox is just that - video only.   You will need a separate digital audio connection from the XBox to the receiver - either digital coaxial or digital optical/toslink - use whatever is available on both devices, or if each has only one, you can get a converter box that will convert coax to toslink, too.   In your receiver's input setup, you will need to "match" the HDMI input you used for video with whichever audio input you use.
Are you new to the Home Theater Forum? Stop by the New Member Introductions area and introduce yourself! See you there!
#3 of 7 OFFLINE   ceemrice
ceemrice
  • 4 posts
Posted December 13 2012 - 07:10 AM
Jason, Thank you for the quick reply. I will search for the converter and optical cable. I'm trying not to 'go for broke' with the converter, since I won't always have the 360 set up there all the time. Any suggestions that pop in your head? -Chris
#4 of 7 OFFLINE   Jason Charlton
Jason Charlton
    Producer
  • 3,103 posts
Posted December 13 2012 - 07:23 AM
Here's a converter from monoprice.com.  It includes an optical input as well, so it will combine the component video and digital audio signal into the resulting HDMI output.
Using the optical connection here simply means you won't have to do the input assignment on the receiver.  If it works, great, if not, you simply unplug the optical cable from this converter and plug it into the receiver.  If you move the XBox around, this might be nice because it will mean you only have to plug in HDMI wherever you go and not have to worry so much about configuration...
Monoprice is a great source for cables, too.  Here's a 6 foot toslink.
Amazon has some, too, but I've shopped for other HT-related stuff from monoprice (and I get all my cables/wire from them) and can vouch for their customer service and quality.
Good luck!
#5 of 7 OFFLINE   ceemrice
ceemrice
  • 4 posts
Posted December 13 2012 - 07:33 AM
You are the MAN! I will order this configuration right now. I really appreciate the help!! :cool:
#6 of 7 OFFLINE   ceemrice
ceemrice
  • 4 posts
Posted December 16 2012 - 05:07 PM
Jason, I just wanted to drop in and give an update. The converter and toslink that you recommended came in yesterday and all works seamlessly. Thanks again! :cool: -Chris
#7 of 7 OFFLINE   Jason Charlton
Jason Charlton
    Producer
  • 3,103 posts
Posted December 16 2012 - 05:56 PM
Great!  Thanks for the update.  It's always nice to hear when things work out.  Enjoy!
