LWanTeD
- Dec 7, 2012
- Tony
Hello everyone,
I found an old surround speaker system that I used to use with my PC.
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16836116140
I want to use to connect it with an AV receiver, and I'm not sure that it's possible. Speakers should be fine I guess, not sure about the sub-woofer though. I've been reading about checking the Ohms and not exceed the one of the receiver. Can anyone explain this a bit please?
Anything else I should be checking?
Thanks.
Thanks.
