Jump to content
more help is needed....itunes to android. TIA
  • Please log in to reply
3 replies to this topic
#1 of 4 OFFLINE   Gregg Loewen
Gregg Loewen
    Video Standards Instructor, THX Ltd.
  • 6,362 posts
  • Real Name:Gregg Loewen
  • LocationNew England
Posted December 07 2012 - 01:38 PM
hi guys. I just finished ripping 411 CDs using itunes (on my PC). I did it using the Apple lossless Encoder setting. I am using my PC's HD as a media server. I have figured out how to do down rezs on my ipad and Mac Air (just a setting in itunes that is device specific). So all is good there. However, Id love to have my music on my android phone. How to do this ? Im thinking that the easiest way would be to rip the entire collection to mp3 then just copy over what I want. How can I do this using itunes or another ripping program? Other solutions? Thanks in advance! Gregg
The Sonodome - circa 2001
The Newest Sonotube - circa 2001
Gregg's DVDs updated...sometimes
Lion Audio Video Consultants usually current
#2 of 4 OFFLINE   Gregg Loewen
Gregg Loewen
  • 6,362 posts
Posted December 07 2012 - 05:33 PM
i did some googling and found dbpoweramp... I am trying now with their 21 day free trial. I will report back once ripped.
#3 of 4 OFFLINE   Keith Plucker
Keith Plucker
  • 1,070 posts
  • LocationSacramento
Posted December 08 2012 - 12:23 AM
In iTunes preferences, change your import settings to the format you want for your Android phone, for instance AAC 256 bit. Then, in iTunes, if you right click on the music, there should be an option that says "Create AAC version" or whatever format you changed it to. It will then create a new music file with the specs you selected.
Once that is done, install Google Music Manager then point it to your iTunes library and you can upload all Google compatible files to your Google Play/Music account. From there you can download the music to the phone or just stream. There are probably a number of ways that a smart playlist or sorting could be used to facilitate removing the duplicate songs from your iTunes library although, if you have the space, backing up your library before you start and then restoring the back up might be the simplest.
Also, I believe doubleTwist (haven't used it myself) can be used to move music over to your Android phone and it will convert the Apple lossless files to 128Kbps H264 M4A during the syncing process. If that bit rate is okay with you, that might be the simplest way to move the music over.
-Keith
As far as I'm concerned, it's a damned shame that a field as potentially dynamic and vital as journalism should be overrun with dullards, bums, and hacks, hag-ridden with myopia, apathy, and complacence, and generally stuck in a bog of stagnant mediocrity. - Hunter S. Thompson, 1958, from cover letter he wrote for a newspaper job.
#4 of 4 OFFLINE   Gregg Loewen
Gregg Loewen
  • 6,362 posts
Posted December 08 2012 - 07:30 AM
hi Keith thank you!!
