Llappin
- May 24, 1999
- Leila
I purchased Panasonic DMP-BDT220 Player in September from Amazon and found out in the first week that it had problems when playing "Inception" on blu-ray.
It has pixilation and freezing problems in several scenes and when it happens it skips. This happens only for “Inception” blu-ray. I called Panasonic support and they said there was nothing they could do. They said they had no reports of that problem and they might or might not be able to release a firmware to correct it in the future. By the way I have the latest firmware update.
Unfortunately, I was too lazy to return the blu-ray and thought I would wait for a fix but I haven’t seen any other complaints about this issue so I am thinking maybe I am stuck with a bad unit. Do you think I should return this player? Thank you for your advice.
Leila
Leila
