Jump to content
Denon AVR-1713 or comparable? Polk Audio?
  • Please log in to reply
11 replies to this topic
#1 of 12 OFFLINE   erew99
erew99
  • 351 posts
  • Real Name:Guy
Posted November 26 2012 - 05:52 AM
Hi All, Hope everyone is doing well. I haven't signed in for a long time, but need some more advice. I'm moving into a new home next month and wanted to get a new receiver and speakers. I'm currently using a Sony HTiB (DAVFX-500). I was thinking about getting the following to start: Denon AVR-1713 $389 Polk Monitor 40 - $93/pair Polk OWM 3 - for rears - $100 Polk PSW-10 - $80 Polk CS20 - $170 The room is approx 10' x 20'. I'm not looking to blast my walls out, but to provide a nice clean sound at normal volume. I'd like to crank it up every now and then too. Any feedback or advice on other speakers would be great.
#2 of 12 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,461 posts
  • Real Name:Sam
Posted November 26 2012 - 06:04 AM
As long as the 1713 has all the features you need/want... The only thing I'd change out is the sub. The PSW-10 is close to being the worst sub on the market. I'd rather have the BIC V-80 if you can't spend much more than that.
#3 of 12 OFFLINE   erew99
erew99
  • 351 posts
  • Real Name:Guy
Posted November 26 2012 - 06:12 AM
The avr1713 has the features I would use... 5.1 + the newer codecs... Dolby TrueHD and DTS-HD. I believe it can do Dolby Pro Logic, but I don't see it on the features list. Any difference between the 1613 and 1713? I'll take a look at that sub.
#4 of 12 OFFLINE   erew99
erew99
  • 351 posts
  • Real Name:Guy
Posted November 26 2012 - 06:23 AM
I've updated by cart with the BIC V80. Looks like a great sub on paper. Are there any other changes you'd make the the rear/front/center speakers? I'm really looking for some type of entry level system so that I can upgrade later on piece by piece. The chose the CS20 (Center) because I believe that is nice center speaker, and a good place to start.
#5 of 12 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,461 posts
  • Real Name:Sam
Posted November 26 2012 - 06:31 AM
1613, you lose(from the product page)... 1 HDMI Aud XT, you get regular Multi EQ 2nd zone pre-out. If you can live without Multi EQ XT and you don't need 6 HDMI... Neither one has component video...which in this day and age, you only need if you have a Wii or an older "not compatible with HDMI" XBox(if there are any of those left still working...). And even then, you can buy the "Wii to HDMI"...
#6 of 12 OFFLINE   erew99
erew99
  • 351 posts
  • Real Name:Guy
Posted November 26 2012 - 06:40 AM
That's exactly why I'm not worried about a NON-HDMI output from any device. I'd like the Aud XT though. 1713 it is. Thanks for the help, and if you have any other speaker recommendations that would produce the same sound as the Polk speakers, but for less $$, please let me know. Thanks!
#7 of 12 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,461 posts
  • Real Name:Sam
Posted November 26 2012 - 06:42 AM
Make sure you can live with the BIC warranty terms... BIC requires you to mail them a "bad part" and wait for the replacement. Granted...most sub manufacturers are that way. If you have a problem with it...you, yes you...have to remove the driver or the amp(the only two parts that "can go bad") and mail it. Some (Epik is one I think) will mail you the replacement part on their dime...with a return envelope. So keep that in mind with BIC. You pay shipping to them...they pay shipping back.
#8 of 12 OFFLINE   erew99
erew99
  • 351 posts
  • Real Name:Guy
Posted November 26 2012 - 06:50 AM
Ugh! I am not a fan of removing parts myself... if that were the case, I can just purchase a replacement part myself... I'd prefer to spend a little more with a better warranty procedure. I've looked at a few subs, but not sure which are actually any good. The closest audio store is in the city, which is pretty far from me. What are some good subs I can take a look at? I guess price point being $100 - $200.
#9 of 12 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,461 posts
  • Real Name:Sam
Posted November 26 2012 - 07:08 AM
Well, at your price range...pretty much all there is is Dayton(Parts Express) and BIC. As far as I know Dayton has a "remove it yourself" warranty as well. That is one of the reasons you can buy the sub for <$200 instead of $300. And Epik, which I mentioned prior, is also "remove it yourself"...except they pay shipping both directions...and mail you the part first(which this aspect is the "perk" over BIC). If Epik has changed that(which I doubt) policy, I'd like to know(I "could" just read their warranty...but that is what it was last I looked). But "remove it yourself" is what you are going to find on pretty much every "you bought it off the web" subwoofer.
#10 of 12 OFFLINE   erew99
erew99
  • 351 posts
  • Real Name:Guy
Posted November 26 2012 - 07:13 AM
I see. For now I'll go with the BIC. Hopefully upgrade in a year or so. I've decided to also remove the OWM3 speakers and instead get a 2nd pair of Monitor 30s. The price is actually cheaper too, but only by about $10.
#11 of 12 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,461 posts
  • Real Name:Sam
Posted November 26 2012 - 07:14 AM
If you aren't hanging them on a wall...there really is no reason to buy the OW series...as OW stands for...On Wall.
#12 of 12 OFFLINE   erew99
erew99
  • 351 posts
  • Real Name:Guy
Posted November 26 2012 - 07:16 AM
Yes. I am not sure how I'll be setting up the room just yet, so I figured I'd go w/ the bookshelf. Later I'd like to upgrade to some TSI floor standing speakers in the front. Thanks for all the help.
