Jump to content
A warning to Blu-ray owners re: water damage
  • Please log in to reply
4 replies to this topic
#1 of 5 OFFLINE   Vincent_P
Vincent_P
  • 1,760 posts
Posted November 13 2012 - 10:24 AM
I just wanted to put this out there re: flood/water damage and Blu-ray discs. After a friend's apartment got flooded due to the recent superstorm, we've been picking through the damage and salvaging what we can. This includes going through hundreds of DVDs, HD-DVDs, and Blu-rays that were submerged in the flood. While I knew the cover art was gone, I figured I'd be able to salvage all of the discs themselves. In the cases of the DVDs and HD-DVDs, no problem- they all cleaned off fine. In the case of the Blu-rays, not so lucky. So far, I have five Blu-rays that have been destroyed due to the water damage (including two Criterion titles). It seems the water got under the anti-scratch protection layer, fogging the discs and rendering them unplayable. Just a word of warning- water and Blu-rays don't mix! Vincent
#2 of 5 OFFLINE   Mark Cappelletty
Mark Cappelletty
  • 2,136 posts
Posted November 13 2012 - 10:29 AM
Oof. Good to know. Best of luck to your friend -- I've been maniacal about taking pictures for insurance purposes ever since my crappy old apartment was robbed over ten years ago.
#3 of 5 OFFLINE   BJQ1972
BJQ1972
  • 58 posts
Posted November 13 2012 - 10:39 AM
The reason that optical discs use polycarbonate rather than other polymers with similar optical properties is because of polycarbonate's low water absorption, so they should be OK with water, but if it is a problem with the durabis, as you suspect, that is very good to know.
#4 of 5 OFFLINE   Vincent_P
Vincent_P
  • 1,760 posts
Posted November 13 2012 - 10:41 AM
I'm pretty certain it was the anti-scratch layer, as it was literally buckling and peeling off the discs, as well. Vincent
#5 of 5 OFFLINE   BJQ1972
BJQ1972
  • 58 posts
Posted November 13 2012 - 10:55 AM
Vincent
It certainly sounds like the anti-scratch layer if they've gone cloudy. The single layer of PC compared to the double layer of PC in a DVD should make water ingress less likely.
