Jump to content
Denon AVR1312 Blinking Power Light/Button
  • Please log in to reply
5 replies to this topic
#1 of 6 OFFLINE   denonavr1312
denonavr1312
  • 26 posts
Posted October 30 2012 - 05:06 PM
Hello. Still lots to understand about this Receiver but a question I have is that the Power Light blinks continuously instead of staying on steady. I thought I had read something about this in the Manual but cant seem to locate it now. I would think it should be steady? Any ideas? Thanks.
#2 of 6 OFFLINE   Dave Upton
Dave Upton
  • 2,054 posts
  • Real Name:Dave Upton
  • LocationHouston, TX
Posted November 01 2012 - 05:27 AM
Denon has some service bulletins out for xx12 models for a grounding issue. Follow these instructions for a factory reset, and if they don't help, I suggest getting it repaired.
#3 of 6 OFFLINE   denonavr1312
denonavr1312
  • 26 posts
Posted November 01 2012 - 06:21 AM
Thanks very much David, will try that out and advise. It seems to go steady after a long time but can be annoying while it is on. Cheers/Bill
#4 of 6 OFFLINE   denonavr1312
denonavr1312
  • 26 posts
Posted November 01 2012 - 06:58 AM
That seems to have worked David, will keep an eye on it in case it happens again. Again thanks very much. I have some questions on the inputs/outputs to this receiver. Wonder if you would be able to give me some assistance on that if I post a block diagram? Thanks again./Bill
#5 of 6 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,784 posts
  • Real Name:Sam
Posted November 01 2012 - 07:10 AM
What kinds of question on the in/outputs? And keep that "processor re-set" in your frontal noggin, you'll use it often.
#6 of 6 OFFLINE   denonavr1312
denonavr1312
  • 26 posts
Posted November 01 2012 - 08:45 AM
Ok, thanks. I'll post the diagram as a separate question under a new title so it may assist someone else. Cheers/Bill
